PIAA 19 x 9.5 fr & 19 x 10.5 Rear. will they fit?
Old Sep 26, 2005 | 07:38 PM
jp's350z's Avatar
jp's350z
Default PIAA 19 x 9.5 fr & 19 x 10.5 Rear. will they fit?
I am considering buying a set of PIAA's Super Rozza wheels fronts are 19 x 9.5" and the rears are 19 X 10.5" they say the specs are as follows
The two 9.5" wheels have a pattern and offset of 5x114.3+20mm (offset was taken from a website). The two 10.5" wheels have a pattern of 5x114.3. The offset is believed to be 30mm, but other sources have advised it is 35mm. They were mounted on a 350Z and fit perfectly until the aftermarket brakes were put on (StopTechs - the 14" rotors were too large for the rear wheels to fit over, which is why they were not used). Please check with your dealer to make certain that it will fit your vehicle.
will the rear 19 x 10.5" fit without rolling the fenders?
Are the offsets correct?
Thanks guys!!
Old Sep 27, 2005 | 10:06 AM
barthelb's Avatar
barthelb
Master
My friend on here has that same setup. However it is on a G35 which should be close too if not the exact same size and fitment issues. PM him his screen name is anotherg35
That way you can find out his offset.
Old Sep 27, 2005 | 10:49 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I was considering those wheels for a while. Every time I got a quote, the size application for the Z was 9.0" front and 10.0" rear.
I could be wrong, or there could be multiple fitments available. Just a heads up.
Old Sep 27, 2005 | 12:35 PM
jp's350z's Avatar
jp's350z
thanks for your help guys. I will definetly look into before buying.
Old Sep 27, 2005 | 12:41 PM
mpol99's Avatar
mpol99
Are those the eBay ones? I was just looking at 'em today
http://cgi.ebay.com/ebaymotors/19-Pi...spagenameZWDVW
Old Sep 27, 2005 | 12:56 PM
jp's350z's Avatar
jp's350z
yes
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
