Relocate battery to rear?
Old Oct 19, 2005 | 07:02 PM
MustGoFastR's Avatar
MustGoFastR
Default Relocate battery to rear?
I removed my spare and tools, so was thinking it's be ideal to relocate the battery to the rear of the car, right? Anyone done this? What would be the best location and how difficult would this be to do?
Old Oct 19, 2005 | 08:42 PM
rockinbboy's Avatar
rockinbboy
Do you plan to you put your spare tools into the front of the car where your battery used to be?
Old Oct 20, 2005 | 05:51 AM
MustGoFastR
Uh... no.
The whole point is to remove some un-needed weight from the car, but with the extra space back there, figured it would be better to move some weight from the front to the back to take some weight off the nose and put it on the rear wheels for better traction/balance. don't know if it's really enough to make any kind of difference to make the project worth the effort, hense my request for thoughts on the idea and wondering if anyone else has done this.
I've seen it brought up a couple of times, but never discussed in depth (both the effects on handling of removing the spare/tools and the idea of relocating the battery).
Maybe easier just to get a light weight battery up front? Any recommendations?
Old Oct 20, 2005 | 06:56 AM
zedated's Avatar
zedated
If you do it, you'll need to get a different kind of battery, one that is completely sealed to keep sulfuric acid vapors from seeping into the passenger compartment.
Old Oct 20, 2005 | 08:41 AM
Swiffer's Avatar
Swiffer
mmmmmmmm...vapors
Old Oct 20, 2005 | 09:35 AM
The Brickyard Rat's Avatar
The Brickyard Rat
Not worth it, imo.
Old Oct 20, 2005 | 09:42 AM
NzZ's Avatar
NzZ
Yeah the thing is the extra cable will add a little weight..and you can probably buy a lightweight battery (Optima yellow top?) that would accomplish a similar effect with less time and trouble.
NzZ
Old Oct 20, 2005 | 09:49 AM
mdracer76's Avatar
mdracer76
Go this route...
http://www.brailleauto.com/
great battery!
Old Oct 20, 2005 | 10:41 AM
MustGoFastR
Dang, that one small battery! Expensive little sucker, too... I'm not that hardcore...
Old Oct 20, 2005 | 12:00 PM
zedated's Avatar
zedated
Holy carp... a Sears DieHard for the Z weighs 39 lbs., the Braille weighs 11.5 lbs!
Old Oct 20, 2005 | 02:24 PM
rockinbboy's Avatar
rockinbboy
The shift in weight so minimal..that really not worth the extra $ to do it. YOu won't feel a difference.
Old Oct 27, 2005 | 06:32 AM
paulsmansfield's Avatar
paulsmansfield
car has near perfect balance anyway. Fuel levels would make more difference than battery would
Old Oct 27, 2005 | 09:56 AM
MustGoFastR
Yes, but balance is upset slightly when you remove the spare and tools. Gas tank is pretty well centered in the car, so not a big issue there. I could tell I had a little less grip in the rear when I took out my spare and tools, so that's why I thought it would be nice to relocate the battery to the back. Prob. not worth it, though. Have the Nismo suspension now and grip is much improved, so I don't think I'll mess with anything.
Old Oct 27, 2005 | 10:09 AM
Fletch69z's Avatar
Fletch69z
It's a lot of work for a minimal diff. Just depends on whether it's worth it to you to do the work, .
Old Nov 5, 2005 | 04:11 PM
alininger2001's Avatar
alininger2001
The battery is pretty close to the center anyway, it won't make much of a difference.
Old Nov 5, 2005 | 06:06 PM
35oZephyR's Avatar
35oZephyR
I've thought about this too...especially with the Spare and tools gone....
Those race cars have gigantic wings in the back to balance the rear-end out. Most of us don't so I wonder how I could transfer some front weight to the back.
You'd need some sort of distributor, and a battery case to house the battery so it doesn't leak any fumes into the car. After it's all said and done, the lightweight aftermarket battery would probably be the better alternative.
Still doesn't settle the deleted spare tire and tools.
Old Nov 5, 2005 | 06:48 PM
onebadfyvo's Avatar
onebadfyvo
I did it on my '90 Mustang LX Coupe. I can say that it made a HUGE difference on my stang since that particular car was notrious for being nose heavy. Also, I had a Paxton SC, so it was almost necessary to put the weight of the battery to the back. After the mod, the turn-in was so much better and the steering became lighter.
I agree that the Z has neer perfect balance, so unless you are thinking about putting a turbo or a SC, I'd leave the battery where it is.
If your set on putting the battery in the back, make sure you use the biggest guage wire that you can find (1 guage).
sales@czp
Sep 23, 2019 03:30 PM
