Do 17" Enkei RPF1s fit over 13" Stop Techs?
Old Oct 20, 2005 | 04:27 AM
knight_white99's Avatar
knight_white99
Default Do 17" Enkei RPF1s fit over 13" Stop Techs?
I'm curious if 17x9" Enkei RPF1s fit over 13" Stop Techs or Brembos. These seem to be the lighest readily available wheel out there at the moment (15.9 pounds) that doesn't cost over $500 each.
Anyone have these over their Stop Techs or Brembos?
Thanks.
Old Oct 20, 2005 | 01:39 PM
homiusang's Avatar
homiusang
It's just a matter of the offset. PM Jason@Perfornance and you will have an answer.
Old Oct 21, 2005 | 07:53 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
the front 13" or rear?
Old Oct 22, 2005 | 09:38 AM
zman2's Avatar
zman2
Default Front 13" Stoptechs
Front 13" Stoptechs
Old Oct 22, 2005 | 10:22 AM
Jason@Performance
Performance Nissan
Ill see what I can find on monday...
Here is the issue...
17x9 +35 will have to have a spacer anyway to fit on the front of the 350Z...
17x9 +22 will fit without a spacer but is special order...
17x9.5 +38 will have to have a spacer to fit on the front of the 350Z...
17x9.5 +18 will fit but have to stretch the tires (like a 245 so will be pointless)...
The 17x9 +35 will need a 15mm spacer to fit properly on the 350Z
The 17x9 +22 will be just a 1mm inside more the wheel well then the 35mm with the spacer but, the spoke angles will be different...
similar thing to the 9.5... would need a 10mm spacer for the 17x9.5 +38mm... but I need to check the spoke angles...
ill let you all know on monday...
Old Oct 22, 2005 | 04:08 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
17x9 +22 fits
Old Oct 22, 2005 | 06:21 PM
knight_white99
Thanks, guys. You saved me a lot of headaches.
Rev_Night
Nov 7, 2020 06:00 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350z82
Oct 1, 2015 06:25 PM
