Pic Request: Lighweight 18" wheels?
Old Nov 1, 2005 | 10:56 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
Default Pic Request: Lighweight 18" wheels?
Post pics of your lightweight 18" wheels. I am turning my car into a track vehicle and sticking with 18" wheels. I need them to be light and strong. And also look good . Anybody know the wieght difference between the old style OEM Ray's wheels and the Nismo LMGT4s? Thanks in advance.
Old Nov 1, 2005 | 11:14 AM
XLR8SN's Avatar
XLR8SN
Cant comment on the weight between the OEM version and the LMGT4's. However, have you considered getting the 5Zigens? The 5Zigen FN-01R-C 1 Piece Casting Wheel, are pretty light. Large enough to accomadate most BBK and wide enough at 9.5. They are also relatively inexpensive. Even Gram Lights would be a good choice. There are several choices...either the 57F/57C or 57S/57S-Pro...a lot cheaper than the Nismo versions. Gram Lights 57S - 18X9.5 +22 (face 2) all around for like $390 or even cheaper from some other places I am sure.
If its for the track only.....whatever rims you choose will get beat up in time. Why spend all the money on really good rims??
Just a thought. Goodluck though.
Old Nov 1, 2005 | 11:29 AM
SinCity350Z
Track Whore
I will look into those wheels. Thanks.
I don't mind spending the money for quality rims as I only do HPDE stuff for now. I just want something that can hit a rumble strip or two without cracking.
Old Nov 1, 2005 | 11:56 AM
I suggest that you visit autocross and track forum, and check member wheels. There are also wheels available for racing which are not street recommended.
Old Nov 1, 2005 | 12:47 PM
NzZ's Avatar
NzZ
Aside from the obvious cosemetic differences, LMGT4s are wider than the OEM track rims and can consequently fit larger tires. Also I believe the LMGT4 has a slightly more aggressive offset. Otherwise the two are similar in weight, quality, etc. LMGT4s are also available in 19" fitments.
Good luck,
NzZ
Old Nov 1, 2005 | 01:04 PM
Zivman's Avatar
Zivman
SSR Comp-H
18x9 fronts are about 18 lbs
18x10.5 rears are around 19.5 lbs
The width of the wheel really affects weight. Maybe go for a 18x9 on all fours for a track setup:
Old Nov 1, 2005 | 04:28 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
first define your budget, and from there the decisions tend to make themselves
Old Nov 1, 2005 | 08:44 PM
Triple8Sol's Avatar
Triple8Sol
Enkei RPF1. Cast, cheap, strong, track-proven, comes in a variety of sizes, and are lighter than other similar wheels like the 5Zigen FN01R-C, etc...
Old Nov 1, 2005 | 10:49 PM
SinCity350Z
Track Whore
Right on. Thanks guys.
Old Nov 3, 2005 | 06:51 PM
eyustfu's Avatar
eyustfu
Advan RGII's are pretty light too
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
