Performance difference between 18" and 19" wheels
Old Nov 8, 2005 | 12:35 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by defex
Doesn't the extra grip with the wider tire help performance though? No one is taking that into consideration. This is the reason high performance cars go with wider tires..is it not?
So, any reason you can't run a smaller diameter rim with a wider tire? No.
Old Nov 8, 2005 | 03:28 PM
defex's Avatar
defex
Exactly how big of a tire can you put on a 7.5 inch rim? I'm looking at some 5zigens... I was shying away cause they were only 7.5... I come from Mustangs and bmw's that have 9+ inch wheels on the back.. so I'm not used to this.
Thanks
Old Nov 8, 2005 | 03:40 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Thanks
Correction:
Any reason you can't buy a SMALLER DIAMETER rim with a WIDER PROFILE, thereby being able to SAFELY put a wider tire on it?
No.
Example, I think Jason@performance (or someone) has 17x11 in the back.
Old Nov 11, 2005 | 10:30 AM
guppies211's Avatar
guppies211
Originally Posted by Strife350z
believe what you will ... but i gurantee your car is slower than before in overall acceleration
Please enlighten us with how much of a difference? Looks like Nissan went with 19s for the 06 model. Would it be legal for them to post the same performance #s? I'll do some testing with my Gtech pro later on. Are you rolling on some light weight volks?
Old Nov 11, 2005 | 08:02 PM
Strife350z's Avatar
Strife350z
unknown because i don't know the wheel and tire weights of the new 19s in the 2006 model
and the question is moot because nissan doesn't post performance numbers... magazines do. Nissan publishes specs.
Old Nov 11, 2005 | 08:52 PM
wvz's Avatar
wvz
Does any one have info on the weight of the various stock rims? Like the 17s on the enthusiast vs the 18s on the touring, etc?
Depravity
Oct 1, 2015 04:49 PM
