255-40-18Rear & 235-40-18Front
Old Nov 8, 2005 | 11:59 AM
froggy's Avatar
froggy
Default 255-40-18Rear & 235-40-18Front
Hello, does anyone drive this set up? I know the speedo will be off, the stagger is preserved, improved final drive,weight,inertia, stiffer sidewall...what about the ABS system? Thanks for sharing your experience.(Been through the Search)
Old Nov 8, 2005 | 11:50 PM
froggy's Avatar
froggy
Come on! Nobody had/has these tire size? Any ABS issue?
Old Nov 9, 2005 | 03:12 AM
lowrider's Avatar
lowrider
It would be better to put a 245/40/18 in the front, it's closer to the OD of the stock 225/45/18 wheel, and will perserve the stagger. It will also reduce the understeer of the automobile. 255/40/18 in the rear should be fine, however with a 235/40 in the front, that may be a little too much stagger for the electronics to handle, though I'm not sure.
Lou
Old Nov 9, 2005 | 03:28 AM
froggy's Avatar
froggy
Thanks Lou for writing back, I know that 245-45R & 245-40F is working : It's what I currently have. I'm going to the track more often. These tire seem great for everyday + track : http://www.tirerack.com/tires/tires....VAN+Neova+AD07
The stagger will be ok with 255-40R & 235-40F(VDC ok), plus all the advantages,but what about the ABS system?
Old Nov 9, 2005 | 05:21 AM
daytona350z's Avatar
daytona350z
eh, i kinda run that setup.
i run 235/45/17s front whis is ~the same as 235/40/18 and 255/40/18s rear. just cuz i burned out my 18s drifting. car behaves the same, with a lil more understeer. but thats bout it
Old Nov 9, 2005 | 08:10 AM
froggy's Avatar
froggy
Thanks daytona350z, anyone else has the same size as I stated above? I know the Z is very sensitive (I had vdc abs issues with only the new front tires without replacing the rears for example) so please answer me if you know from your experience.
Old Nov 9, 2005 | 07:26 PM
SP Racing Parts's Avatar
SP Racing Parts
I have run a 245-35-19 front a 275-30-19 rear or a 245-30-20 front and a 285-30-20 rear with no problems
Old Nov 9, 2005 | 11:29 PM
froggy's Avatar
froggy
Without VDC, right? This is still not the sizes I mentioned above...
froggy
May 28, 2005 01:29 PM
