New tires without old ones being worn
Old Nov 10, 2005 | 02:32 PM
Daytona350Texas's Avatar
Daytona350Texas
Default New tires without old ones being worn
Im looking to upgrade from stock tires with only >5k miles... for some Nitto 555. If I buy them is it good to buy nitto on all 4 considering front 2 have hardly any wear... could i just replace back 2 for basically racing and keep front 2 stock tires for now? or will that feel weird on handling and smoothness etc....
Old Nov 10, 2005 | 07:35 PM
The Brickyard Rat's Avatar
The Brickyard Rat
Don't mix tire brands.
Old Nov 10, 2005 | 10:52 PM
Daytona350Texas
im not trying to mix brands im just saying is it really necessary to buy 4 tires when the front 2 have over 90% tread...
Old Nov 10, 2005 | 11:37 PM
Sponge's Avatar
Sponge
He says this for a good reason. If you have VDC or TCS, replacing just the front or rear tires, regardless if they are worn or not, can play hell with the traction control systems. This is primarily because differnet brands have differnet sidewall heights and mixing brands will set off the VDC and TCS.
I have direct experience with this. I replaced the OEM rears only at 12k miles and found that high speed braking and even semi-agressive cornering would cause the VDC to "auto-brake" the fronts because VDC sensed the fronts spinning faster due to higher sidewall heights. NOT the situation you want while driving at highway speeds and cornering. Replacing the front immediately made this problem go away.
Don't be cheap and just replace the rears. The Z is a sports car, and the general rule with sports cars are to replace all 4 tires at once. I didn't believe this maxum at first, but I am a believer now. Don't put yourself at risk and find yourself in a dangerous situation when you least expect it by comprimising the handling of the car you paid good money for.
Old Nov 11, 2005 | 12:05 AM
Daytona350Texas
wow.... well said. Eh im 19 and learning, this is first car im buying for myself so im basically learning. Never delt with such power, had a 5speed 92 camaro before this, was fun, but not nearly as luxurious and powerful. but i have drivin my fair share of mustangs cobras and vettes... all fun as well so i was just wondering thank you
Obadabot
Jun 18, 2023 11:31 PM
ablaine
Nov 29, 2016 10:13 AM
samansharif
Sep 25, 2015 12:31 PM
