Work Wheels Thread
Old Jul 26, 2013 | 12:17 PM
  #1121
makstraw's Avatar
makstraw
15 weeks later I finally recieve that permanent smile on my face
Old Jul 26, 2013 | 02:40 PM
  #1122
SR71's Avatar
SR71
Lead Super Moderator
YOU SUCK
I may be a little jealous about your wheels
Old Jul 26, 2013 | 03:12 PM
  #1123
2bad240's Avatar
2bad240
Cleaned mine up a little bit today.
Old Jul 26, 2013 | 09:26 PM
  #1124
350Zensokou's Avatar
350Zensokou
Old Jul 27, 2013 | 01:47 PM
  #1125
sofa king's Avatar
sofa king
Your wheels look almost as deep as mine, almost.
Old Jul 27, 2013 | 04:14 PM
  #1126
reuben350z's Avatar
reuben350z
all I wanna do after lookin at some of these
I need me some works
Old Jul 28, 2013 | 03:41 AM
  #1127
sithlordsoup's Avatar
sithlordsoup
18x9.5 +30 (F) 18x9.5 +20 (R) Temporary plasti-dipped white. lowered on $200 Tein S-tech Springs
Akebono 370z brakes with 18s give it that ridiculous looking Ferrari brake clearance.
*Ordered a pair of white CR kiwamis on arriving on Thursday (18x10.5 +22) Can't order the other two wheels until next month.
Old Jul 28, 2013 | 08:52 AM
  #1128
makstraw's Avatar
makstraw
updates for you. Had to clearance my front calipers a little its so close.
I may be a little jealous about your wheels [/QUOTE]
Old Jul 28, 2013 | 08:56 AM
  #1129
makstraw's Avatar
makstraw
pics jacked up in size
Old Jul 28, 2013 | 09:01 AM
  #1130
Bmurray350z's Avatar
Bmurray350z
looks great. looks like you could use a small spacer
Old Jul 28, 2013 | 10:12 AM
  #1131
323_z33's Avatar
323_z33
White work xd9 18x9 +18 18x10+20
Old Jul 28, 2013 | 11:11 AM
  #1132
KingBaby's Avatar
KingBaby
Hardest Setting
balling color scheme...
Old Jul 28, 2013 | 03:19 PM
  #1133
makstraw's Avatar
makstraw
Thanks
Unfortunately yes, a 3mm would be great. I still have to play with my height and camber too. Im having problems hitting my momentum uppers in the front when I try to zero out the camber....
Old Jul 28, 2013 | 08:20 PM
  #1134
fataLblitz's Avatar
fataLblitz
Old Aug 8, 2013 | 06:39 PM
  #1135
SkyNinja31's Avatar
SkyNinja31
Default Works VS-XX Fitment
I'm currently running on Eibach Sportline lowering springs and I just wanted some opinions and suggestions for the new wheels. I really like the Works VS-XX and hopefully trying to get them on with a proper setup , I been looking around the forums and searching others setup but I just wanted to be sure if these would be okay .
1.2" Drop front and rear
-but I'm changing to some BC Br coilovers soon .
19x9.5 +7 Front w/ 4.25" lip (A-Disk)
19.10.5 +7 Front w/ 4.5" lip (R-Disk)
225/35/19 Front
255/35/19 Rear
Will I be fine on just Eibach or should I just go get the coilovers? Any spacer suggestions? Probably going need to roll or pull my fender?
A friend of mines said that I need a camber kit for it, any suggestion for good ones? Thanks and yes I tried searching.
Old Aug 8, 2013 | 08:35 PM
  #1136
RawrXTC's Avatar
RawrXTC
I'm sure with the coilovers you will need a camber kit and possible new toe bolts. The most commonly used ones seem to be SPC. Your tire size seems to be really small for the width of your wheels. I suggest 245 front and 275 rears at least. Will probably need to roll. Someone else with more experience will charm in; I'm sure.
Old Aug 9, 2013 | 04:41 AM
  #1137
GothamZ's Avatar
GothamZ
Those tire sizes will give you a little stretch, if that's the look your going for. Offset wise, you will probably have to roll the rears.
RawrXTC is right, SPC camber parts are typically what most people get, check into them, you should go ahead and get them.
The decision to whether to go ahead and get the coils or just sit on your eibachs is all up to you. If your trying to go with the stretched/slammed look, go ahead with the coils and those tire sizes. If you want it to look nice & flush, id go with the tire sizes Rawr said and camber kit with your eibachs and a nice roll and it would look pretty nice.
that's my input just from some experience ive ran into with similar offsets & wheel sizes. Hope it helps.
Old Aug 11, 2013 | 01:55 AM
  #1138
1001's Avatar
1001
you should have a rear camber kit if you are currently on eibach sportlines. Rear needs to be rolled for sure. i'm on eibach sportlines with spc rear camber and toe bolts running work s1r 19x10 +7 and 19x11.5 +5 with 245/35 and 275/35. rears are rolled and fronts are pulled
Old Aug 25, 2013 | 05:11 AM
  #1139
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Old Aug 27, 2013 | 08:13 PM
  #1140
Blackheart's Avatar
Blackheart
Default Another thread
Love my Meisters, need to do a shoot soon!
