Please help, trying to install rear camber arm
Old Nov 12, 2005 | 08:30 PM
solarscar's Avatar
solarscar
Default Please help, trying to install rear camber arm
Hi, I bought these camber arms off ebay and am trying to install them, but i am having trouble removing the bolt as seen in the picture below. I can't get the bolt out, it keeps hitting something.
How do i take these out properly and install the new ones properly? Any advice is much appreciated.
Old Nov 12, 2005 | 08:36 PM
drsifu's Avatar
drsifu
give me a couple of minutes
Old Nov 12, 2005 | 08:40 PM
drsifu's Avatar
drsifu
1. Remove tire with power tool.
2. Set jack under rear lower link (the thing your rear springs sit on).
3. Remove fixing nut and bolt between front lower link and rear suspension member with power tool (i think this is the nut you are having trouble getting out?).
4. Remove fixing nut and bolt between front lower link and axle with power tool.
5. Remove front lower link from vehicle.
that's all i have from the manual, mind you it is for a g35, but thought i'd try to help until someone else with experience steps in.
good luck
Old Nov 12, 2005 | 08:47 PM
drsifu's Avatar
drsifu
i'm hoping by jacking up the rear lower link you will lower the front lower link enough to get you clearance.
Old Nov 12, 2005 | 08:48 PM
solarscar's Avatar
solarscar
Man, i'm just sitting here waiting for some help. Thanks for looking into this, my car is all apart downstairs.
I hope i don't have to remove the sway bar, cause if i do, i need help with that too.
Thanks a lot, i REALLY appreciate the help!!!!!!!
Old Nov 12, 2005 | 08:51 PM
zland's Avatar
zland
Sport Z Magazine
How much did they cost?
Old Nov 12, 2005 | 09:00 PM
drsifu's Avatar
drsifu
based on the service manual, you should not have to remove it
IM me if you need additional info
*EDITED for content*
i have the service manual for the G35, but most should apply to the 350z as well
i'll be here for anothe hour
Old Nov 12, 2005 | 09:13 PM
solarscar's Avatar
solarscar
Okay, i am downloading yahoo messenger.
They were $125.00 for both of them i think. I tried to place another jack under the plate that has the big rear spring in it and jacked it up but it the bolt is still hitting the sway bar. I don't see how i can get the bolt out without removing the sway bar.
Old Nov 12, 2005 | 09:24 PM
drsifu's Avatar
drsifu
hmm...looking at that pic...
can you just remove the stabilizer clamp to give you the extra 1/2" you need to remove that bolt?
Old Nov 12, 2005 | 10:09 PM
GaryM05's Avatar
GaryM05
+1. It looks like you should just be able to remove that sway bar bracket that the bolt appears to be hitting. You shouldn't need to remove the whole sway bar, just that one bracket that's causing the trouble. Good luck!
Old Nov 12, 2005 | 10:10 PM
solarscar's Avatar
solarscar
Okay, here it goes....
I'll be back to comment on my progress
Old Nov 12, 2005 | 11:57 PM
overZealous1's Avatar
overZealous1
i had to remove mine. prolly the amount of time to post again and read responces you could of had it done, lol. good luck, it really is a ***** to get the alignment close to even make it to the alignment shop, very touchy on the toe when you correct the camber and vice versa.
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
