Keep bending my wheels! :(
Old Nov 13, 2005 | 09:50 AM
aprikh1's Avatar
aprikh1
Default Keep bending my wheels! :(
Does anyone else have a problem with running a 35 tall tire on a 19 inch wheel? This is the 3rd time that I hit a pothole and bent a wheel. I have Volk SF-Challenges and I was wondering if can switch to a taller tire. Perhaps a 45? Thanks
Old Nov 13, 2005 | 10:05 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I hit a couple of motherfocker potholes since getting the SF's... but no bending...
running 35 sidewall.
Old Nov 13, 2005 | 10:50 AM
barthelb's Avatar
barthelb
Master
You have to check the inside of your rims. I have a couple bends.
Old Nov 13, 2005 | 10:57 AM
guppies211's Avatar
guppies211
+1 My wheels bent on the inside as well. Get a tire with stronger sidewalls might help. BFG sidewalls are kind of weak.
Old Nov 13, 2005 | 11:23 AM
aprikh1's Avatar
aprikh1
Well I bent the wheel on the outside. For the third time now! I run GoodYear Eagle F1s are those known for weak sidewalls? Does anyone run a 45 tall tire on the 19s without rubbing?
Old Nov 13, 2005 | 11:42 AM
homiusang's Avatar
homiusang
Default Fyi
Just to let you guys know, the tallest sidewall they make for cars in 19s is 40mm. But you can get 45mm side wall on 18s though.
Old Nov 13, 2005 | 12:03 PM
aprikh1's Avatar
aprikh1
I am not sure about that. TireRack has Pirelli Rossos in 19/45/245 and 19/45/275. The question is would they fit and really how much more cushioning would i get with those tires.
Old Nov 13, 2005 | 12:06 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
=\ Now you are making me worry.
If I'm not losing pressure, then I probably don't have a bend though, right? ....
Old Nov 13, 2005 | 12:08 PM
e46krazy's Avatar
e46krazy
nope , i had a HUGE bend on one of my wheels on the outside where you could se it clearly and it still drove around perfectly fine until i got the rim fixed
Old Nov 13, 2005 | 12:20 PM
jinsei888's Avatar
jinsei888
drive more carefully, it's the price you pay in the tuning arena
Old Nov 13, 2005 | 01:48 PM
Zexy's Avatar
Zexy
Damn what type of potholes do you drive through?
Supposedly the SF dish is forged?
Old Nov 13, 2005 | 01:56 PM
ClaytonC01's Avatar
ClaytonC01
at least you didnt smash the wheel to peices... ive done that..
Old Nov 13, 2005 | 02:58 PM
aprikh1's Avatar
aprikh1
The pothole was not huge by any means. I was doing some spirited driving on some backroads at 3 in the morning and hit this hole in the middle of the road. The pothole was maybe half an inch deep. I felt a pretty strong hit, but nothing terrible. Came out, felt around the rim and it was bent. I thought that the Volks were supposed to be real tough because they are forged. Guess not.
Old Nov 13, 2005 | 06:37 PM
guppies211's Avatar
guppies211
Default bendage
My Work wheels have several bends and still holding air. LoL. My other car has bends and holds air still. Damn potholes.
Old Nov 13, 2005 | 11:41 PM
350ztoronto's Avatar
350ztoronto
i've broken an entired rim in half like a foot deep on the highway dumbarses didnt' even block that part off
Old Nov 14, 2005 | 03:50 AM
35oZephyR's Avatar
35oZephyR
Better a "bend" than crack and shattering then having the car end in a ditch.
Forged wheels are not indestructable, they just hold up alot better than the OTHER wheel-making process.
I also have SF's with 35 series tires...no problems.
Old Nov 14, 2005 | 04:51 AM
Demon Z's Avatar
Demon Z
This is a sore subject that I'm gonna have to come to terms with....I think Ohio would get AT LEAST the bronze medal for sh!tty roads, and as much as I'd like to run 19's and 35's when I upgrade, I'll have to settle for 18's and 40's. Wish I could afford to live in Hawaii.....
Old Nov 14, 2005 | 09:05 AM
Stailey's Avatar
Stailey
what width are ur running?? 255? 275?
if your doing the "stretch" tire look, that could possibly be a factor with your problem. The more meat you have on the ground w/ that 35% sidewall the better. The tire then takes the punishment and not your rims
Old Nov 14, 2005 | 04:27 PM
aprikh1's Avatar
aprikh1
35/255/19 is the size of the tire. Maybe I am just unlucky and the potholes gravitate towards my Z.
Old Nov 15, 2005 | 07:03 PM
funkdamonkman's Avatar
funkdamonkman
My only rim damage was when I hit a 6+ inch deep pothole at around 40mph. 19" 5zigen hyper 5zr with Toyo t1's. 35 sidewall. I only bent the lip though. Have you guys actually made the wheel not a circle anymore? (slightly)
