What wheels are these?
Old Jan 2, 2003 | 05:34 PM
girlracer's Avatar
girlracer
Default What wheels are these?
Anybody know what these wheels are called?
http://www.350tuner.com/veilside.htm
thanks
Old Jan 2, 2003 | 05:56 PM
DBTRACK's Avatar
DBTRACK
Wheels are Veilside wheels.....they are ANDREW RACING GOLT
Old Jan 3, 2003 | 02:08 AM
girlracer's Avatar
girlracer
Thanks DBTRACK! Much appreciated.
Old Jan 3, 2003 | 02:37 AM
veilside z's Avatar
veilside z
Just something to be aware of if you plan on running these...
Front is 19"x9.0J Hi Disk with +19mm offset
Rear is 19"x10.0J Mid Disk with +16mm offset
To clear the Brembo calipers you will also need to fit a 3mm spacer
You can get further information at this address - http://www.veilsideracing.com/newparts.htm
Enjoy
Old Jan 3, 2003 | 09:47 AM
rodH's Avatar
rodH
that is a pretty wild offset, is there any problem rubbing (plus with the 3mm spacer, the offset becomes a +13 and +16) WOW?? Any problems??
Old Jan 4, 2003 | 12:38 AM
veilside z's Avatar
veilside z
You will only need to use the 3mm spacer on the Fronts (to clear the calipers).
I haven't seen these in the metal, but this is the info. from Veilside Japan - Check out the link in my previous reply.
It does give you a great look though, check out the pics on the website.
Version 2 & 3 aero kits are also being launched at the Tokyo Auto Salon late next week!!!
Old Jan 4, 2003 | 02:24 PM
Driven's Avatar
Driven
Well....if this setup is a 9" and 10", I need to assume they are running something like a 245 and 275 tire, correct? And guys are saying a 22+ rear is too close to the fender lip for comfort? This car is obviously lowered also which makes these offsets that much more difficult to believe when considering everything else being discussed on this board.
I was going to go with a front 9" and rear 10" with a 28+ and 25+ respectively with the above mentioned tire sizes with the intent of achieving a "look" like the Veilside setup posted above...but now I am once again confused on offsets....damn this is getting frustrating!
Old Jan 5, 2003 | 02:07 AM
veilside z's Avatar
veilside z
As I said, I haven't seen them in the metal - but these are the offsets & info posted by Veilside Japan on their website.
Maybe you want to drop Veilside USA a mail & run it past them
Veilside USA, Carson, CA - Email: [mailto:info@veilside.com], they may even be able to mount some up (who knows)
Good Luck
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
