** need help fast!! 245/275-35 or 255/285-35? which would be better?
Old Nov 23, 2005 | 07:51 AM
barthelb's Avatar
barthelb
Master
Im thinking it would rub and buldge too much for your front tires. 245's are nearly flush, 255's are probably the best fit on a 8.5 rim. The Re050a's are really good tires. The 285 is flush with just a hint and i mean a hint of buldge, you can't even tell. My friend has the piaas and he has a 275 Michelin PS2 on them and it looks stretched.
Originally Posted by sharingan625
damn. one more question before i go to sleep. how would 265/30/19 work out in the front with 19/8.5 wheels? with 20mm offset. will it rub?
thx.
good night everyone...... zzzzzzzzzzzzzzzz
Old Nov 23, 2005 | 07:59 AM
BhashaZ's Avatar
BhashaZ
Originally Posted by Wired 24/7
Falken, Toyo --> 255/35/19 285/35/19
BFG --> 245/35/19 275/35/19
This is my $0.02 since it seems BFG has slightly wider profile than falken or toyo.
For example, if you get the BFG at 285 you will have some bulge, but falkens will look relatively less bulged at 285.
Toyo are kinda in the middle from what I remember seeing on other people's rims.
EXACTLY! I agree 100%! It's funny because those are always the brands I mention and those are the exact sizes I suggest. Personally I have 245/275 (Toyo). Next time I'm getting 255/285 if I go Toyo, or keeping 245/275 but going BFG.
Old Nov 23, 2005 | 01:44 PM
jp's350z's Avatar
jp's350z
Originally Posted by palepony
"245/45-18 4.3in 13.3in 26.7in 83.8in 756 0.0%"
i assume you meant 245/35/19 instead? since you run 19inch fronts?
stock front
225/45/18 = 26.0"
245/35/19 = 25.8" smaller than stock but not enough to worry
255/35/19 = 26.0" same as stock
all the choices 245 + 275, or 255 + 285, or in the middle 255 + 275 are good choices, its +/- 1cm. i like the 255/275 combo for the reasons i gave before
275 or 285 on a 10inch rim will not look that different, neither too stretched or too bulged
pp
PP
245/35-18 means the stock size i have in the rear of my touring Z! so I was comparing the diffrence between stock and getting a 275/35-19 or 285/35-19
JP
Old Nov 23, 2005 | 01:54 PM
palepony's Avatar
palepony
jp
sorry, yes, on re-reading your post, that makes sense
any closer to a decision?
pp
Old Nov 23, 2005 | 02:01 PM
palepony's Avatar
palepony
sharing
i agree with bartheleb, 265 on a 8.5 rim will bulge. most tire manufacturer's recommend at least a 9" rim for a 265 tire. i run a 255 on a 8.5 inch rim and it fits large
pp
Old Nov 23, 2005 | 02:31 PM
sharingan625's Avatar
sharingan625
i see. so im gonna have to go with 245/35/19 and 275/30/19 for the tires i want. thank you for the confirmation guys.
Old Nov 23, 2005 | 02:58 PM
palepony's Avatar
palepony
whoa there big-guy, no-one confirmed that 275/30/19 is a good idea
those will be approx an inch smaller than stock, if you have VDC/TCS it will be unhappy, will offer less rim protection, have harsher ride, and depending on your rim size will have a more stretched look
275/35 would be a better choice
pp
Old Nov 23, 2005 | 05:13 PM
jp's350z's Avatar
jp's350z
PP
I'm thinking of going toyo T-1R 255/35/19 and 285/35/19. I like the wide tire look!! you think that config. will keep VDC happy?
Old Nov 23, 2005 | 07:39 PM
palepony's Avatar
palepony
jp
255/35/19 is the same size as the stock front
285/35/19 is 0.2" taller than stock rear
so yes, i think that you should be fine with your VDC, however, i have not run that size myself. many others have run 255/285 with no problems, but i suggest you ask them directly to be sure.
glad you found your tires
pp
Old Nov 30, 2005 | 05:04 PM
jp's350z's Avatar
jp's350z
Originally Posted by Tsex On 19s
my 255/285 will be on tom.. a lot of rubber, ill let ya know how it feels...
Did you get the tires yet? How does it look / feel?
JP
Old Nov 30, 2005 | 09:03 PM
2 low Z's Avatar
2 low Z
Originally Posted by gargoyleZ
Here is a 285/30 and 255/35...the rolling diameters are off by 1mm. Bridgestone RE-050.
What size wheels are these. The tires fit nice on there.
seagrasser
Oct 11, 2015 03:27 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
