TPS questions
Old Nov 25, 2005 | 09:13 AM
Jason021174's Avatar
Jason021174
Default TPS questions
are the TPSs transferable to aftermarket wheels? If so, is the warning light settings adjustable for the different tire pressures?
Old Nov 25, 2005 | 09:45 AM
DavesZ#3's Avatar
DavesZ#3
Yes, TPMs will fit SOME aftermarket wheels. On some you can mount them like the factory wheels, on some others, you need to do them with bands, on others they just won't fit.
The setting is not adjustable; it's not part of the TPS, it's in the computer part.
Old Nov 25, 2005 | 01:15 PM
Jason021174
It really doesn't matter to me if the TPS system is in use or not. If I choose not to installed the sensors on aftermarket wheels, can I disable the system so that the light does not come on? Such as removing the fuse or something?
Old Nov 25, 2005 | 01:27 PM
DavesZ#3's Avatar
DavesZ#3
I haven't been able to find a post that appears to have a surefire method for disabling it. Pulling the fuse has been suggested but other have warned that it might disable functions (ABS) that you need.
Old Nov 25, 2005 | 01:38 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
they will fit in pretty much all 1 piece wheels...
2 piece or 3 piece, your on your own...
Old Nov 25, 2005 | 01:39 PM
Jason@Performance
Performance Nissan
but you do not need to use any...
if the pressure sensors are kept away from your Z, then when you drive your car for 40 mins or more, then a small light turns on... it goes away next time you turn off the car...
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
