offset question for 17x9 and 17x10
Old Jan 27, 2006 | 04:52 AM
Kolia's Avatar
Kolia
I thought we had to use spacers up front with these wheels?
Old Jan 27, 2006 | 06:11 AM
Nano's Avatar
Nano
some peole say the 17x9 + 15 is perfect and will fit without rubbing...
some other people say the above combo is too aggressive and reccomend the 17x9 + 35 with a 10mm spacer...
right now I'm on 18x8.5 + 23mm and it looked like this on a stock height car... you do the math
with some load on suspension
Old Jan 27, 2006 | 06:33 AM
Kolia's Avatar
Kolia
Mmmh…
The thing is, I’m more concerned with the position of the contact patch relative to the steering axis. I don’t want to screw the scrub radius to much, while still maintaining wheel and tire clearance to every thing.
I’m assuming a wider wheel, combined with camber, will have a tendency to move the center of force on the contact patch towards the center of the car. Less offset might be desirable to some extent. Like a couple mm.
Stock we’re at +30mm front right? So a +35mm wheel with a 10mm spacer to get +25mm effective offset might be better, steering wise, than +15mm.
Old Jan 27, 2006 | 06:36 AM
Nano's Avatar
Nano
Mmmh…
the front nismo LMGT4 are at 18x8.5 + 30 I believe (or +25?)
Old Jan 27, 2006 | 01:32 PM
03Z33's Avatar
03Z33
Originally Posted by Nano
Where do you get your information from? Grassroots motorsport reviewed both the tires you mention, and the AD07 performed poorly compared to both the 615 and older 215...
http://www.grassrootsmotorsports.com...5_tiretest.pdf
From first hand experience in more driving conditions than just there limited tests... The 215 was a great tire and has a great compound, but the newer 615 is a much harder compound tire and doesn't grip nearly as well as the 215 or the AD07 in the dry or wet. Also during REAL tracking the AD07 won't get greasy like the 215's which "go away" after a few hard laps.
edit: just read the article and it confirms everything I said above, the Falkens work well for cone dodging but at speed and on REAL tracks they don't match the AD07's and the KD's
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
