245/35/19 and 275/30/19. is this ok?
Old Dec 11, 2005 | 11:32 PM
sharingan625's Avatar
sharingan625
Default 245/35/19 and 275/30/19. is this ok?
due to availibility of the sizes on the tires i wanna get, im thinking this.
245/35/19 front and 275/30/19 rear. rims will be 8.5 / 9.5
anybody run similar setup? any problems??
thank you.
Old Dec 12, 2005 | 03:13 AM
palepony's Avatar
palepony
do you have TCS and/or VDC? and do you want it to work?
pp
Old Dec 12, 2005 | 05:55 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
you will have problem with TCS/VDC since the rear smaller than front. However, just turn off TCS/VDC and you will be fine. I had the same set up and no problem so far.
Old Dec 12, 2005 | 07:32 AM
drumma022's Avatar
drumma022
What problems will you get?
Old Dec 12, 2005 | 07:35 AM
Zexy's Avatar
Zexy
Thank God i went with a base....
Old Dec 12, 2005 | 07:43 AM
tonester1011's Avatar
tonester1011
CF God
i got 245/35/19 and 275/30/19 and never had any problems with anything
Old Dec 12, 2005 | 08:01 AM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Ditto. I have TSC and it works fine for the most part. Sometimes when cornering at higher speeds it will kick in, but as for as stright line I ahve no problems, I run with it off most of the time anyways.
Old Dec 12, 2005 | 08:06 AM
gimpster621's Avatar
gimpster621
when i gassed the car, i had the tcs kick in. i just turned it off and no worries
Old Dec 12, 2005 | 08:31 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
the "slip" light will blink when you have a hard acceleration. In addition, you're from CA, you don't have to worry about traction that much.
Old Dec 12, 2005 | 09:48 AM
Z_U_L8R's Avatar
Z_U_L8R
Which tires are you looking at BTW? I too am looking at the Dunlop Direzzas and General Tires Exclaim UHP and am wondering the same thing about those sizes. I know people running Nitto 555s have to run those sizes so they must be okay.
Old Dec 12, 2005 | 10:21 AM
sharingan625
thank you for the info guys.
i have 2004 enthusiast model, which i know i have TCS. but what's a VDC?
and i usually drive with TCS off so that is not much of an issue.
what about the appearance? i heard tire gets a little thicker as it gets wider, but will they look about the same thickness at the front and rear?
and what kind of wheel gap am i looking at with 35 in the front and 30 in the back? am i gonna have to lower the car to reduce the gap?
thank you.
Old Dec 12, 2005 | 10:29 AM
sharingan625
im getting hankook ventus k104. i have the k104 235/45/17 and 255/45/17 on right now. i put on about 25k on it, tires are still pretty new. quiet and durable. traction is ok. not bad. just perfect for daily driving. i can get the 275/30/19 little under $200 and i just can't pass on that deal. i see other brands well over 300 dollars for that size. simply can't afford it.
Old Dec 12, 2005 | 01:16 PM
Nexx's Avatar
Nexx
hrmm, General makes a 265/30/19, wonder if that would work in the front, they also make 275/30/19, tirerack has them for both for 150 or less each. would make a nice combo if 265/30/19 works in the front.
Old Dec 12, 2005 | 02:02 PM
sharingan625
woo. never heard of that brand but that is a killer price. how's general tires like? im looking for daily driving tires. nothing fancy.
Old Dec 12, 2005 | 09:03 PM
Nexx's Avatar
Nexx
everything ive read about general has been positive. they look like nice and have a very nice tread wear rating of 360 i believe. i guarantee they arent the best performing tires but for the price, they give you good performance at a bargain price. read some reviews at tirerack.com
Old Dec 12, 2005 | 09:28 PM
sharingan625
yes. i was just at tirerack reading the reviews. looks very promising.
i was looking at the exclaim one and has the same sizes available.
245/35/19 and 275/30/19 35 series wasn't available for these tires either but that is a killer price.
ill definately consider this.
Old Dec 12, 2005 | 10:15 PM
Nexx's Avatar
Nexx
Just today i broke down and payed $979 shipped for 245/35/19 and 275/35/19 BFG KDW-2's. I figured it was worth the extra hundred. for more sidewall, better looks and not having to worry about throwing off traction control blah blah. Why risk it. Hell I just spent 2k for wheels might as well get good tires, why pinch the pennies, althought it was really tempting.
doublej32
Wheels Tires
Sep 25, 2015 05:05 PM
glenngw3
Sep 11, 2015 05:19 AM
Rob Nance
Texas
24
Apr 15, 2004 12:23 AM
Rob Nance
Apr 1, 2004 12:32 AM
