Wheel spacers on stock wheels?
Old Jan 4, 2006 | 07:47 PM
  #41
Arnie's Avatar
Arnie
Originally Posted by Jason@Performance
I understand...
If its a cookie cutter non-hubcentric spacer then I do not recomend it and you will most likely have those problems...
If it is a spacer like H&R where it is hubcentric and has the extended hub then its safe...
But, nothign is if Hub Rings are not used...
Hub Rings are very important and alot of people dont install them with their aftermarket wheels...
Good point, and make sure that for track use, the hub rings are made of aluminum or steel. Plastic rings are good for street use, but during race use they somtimes tend to deform/compress a tiny bit and thus alow for movement that eventually brakes the wheel studs/bolts. Depending on the driver ofcourse (think of someone who rides the curbstones all the time).
Old Jan 14, 2006 | 03:40 AM
  #42
Chad68's Avatar
Chad68
Originally Posted by TiPIACE
i have 15mm H&R DRM spacers on the rear. One of the very first things i did despite ordering a set of 19s. I dont like the wheel tucked in look either. Looks even worse with lowered springs
i bought both 25mm and 15mm, but the 25mm made the wheels stick out of the guards, im guessing due to the offset on the Anniversary wheels being different to stock 18s
i havent noticed in difference in handling or power down, but still i wouldnt put spacers on the front wheels
http://img.photobucket.com/albums/v2...e/126_2620.jpg
http://img.photobucket.com/albums/v2...e/126_2608.jpg
http://img.photobucket.com/albums/v2...e/126_2604.jpg
Hey tipiace,
You wouldn't happen to have a direct a$$ end shot of your Z with those wheels/spacer combo would you?
I'm kind of interested in what they look like at a rear view.
Old Jan 14, 2006 | 06:07 AM
  #43
TiPIACE's Avatar
TiPIACE
Originally Posted by Chad68
Hey tipiace,
Old Jan 14, 2006 | 04:08 PM
  #44
Chad68's Avatar
Chad68
Thumbs up
Nice, thanks man!
Makes me wish I had the patience to keep a black Z clean.
Old Jan 17, 2006 | 10:20 AM
  #45
sq40's Avatar
sq40
I'm Buying a set of wheels with a 40mm Offset.. What spacers, if any do you think I should Purchase? (17" with stock tire sizes)
Old Apr 28, 2006 | 07:02 AM
  #46
sq40's Avatar
sq40
What is the Correct Torque Setting for Installing the H&R Spacers to the Hub AND the Wheels to the H&R Spacer?
Old Apr 28, 2006 | 08:25 AM
  #47
Jun's Avatar
Jun
Need to re-host, the pics are no longer up
Old Jun 13, 2006 | 03:46 PM
  #48
2005ssm's Avatar
2005ssm
according to the pamphlet I got in the box for my H&R 25mm spacers, the torque value for the spacers is the same as for the wheels
Old Jun 15, 2006 | 01:32 AM
  #49
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
by the way... new link to the H&R spacers on our new site...
http://mynismo.com/products/?id=4182
ablaine
Nov 29, 2016 10:13 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
