-----18x8.5 all around +38 offset-----
Old Dec 20, 2005 | 10:33 PM
eddie lee's Avatar
eddie lee
Exclamation -----18x8.5 all around +38 offset-----
Would 18x8.5 all around +38 offset fit perfect for our Z? Do I need to use any spacer? I might up grade my brake system in the future, would +38 offset leave enough space for the brake upgrade, please give me advise!
Old Dec 20, 2005 | 10:53 PM
thawk408's Avatar
thawk408
I think that is around the same offset as the stock 03-05 Track wheels, might be a +35. The rear track wheels are 18x8.5 and I have rears on all four corners on mine, with the factory brembos. So should work just fine I would assume. If you want you could get some 15-20mm spacers to help make the wheels look more flush with the fenders.
Old Dec 20, 2005 | 11:17 PM
eddie lee's Avatar
eddie lee
I always think the spacer is kind of dangerous, please correct me if I am wrong. For me the performance is way more important than it looks, since I take my Z to the racetrack to beat the 911 and other import cars.
Thank you for your advise!
Old Dec 20, 2005 | 11:34 PM
thawk408's Avatar
thawk408
The spacers will be fine aslong as you get the right ones. My friend works for a BMW raceshop and their racecar has always run spacers and it does great.
Old Dec 21, 2005 | 01:05 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
No. Sorta. But not really.
Old Dec 21, 2005 | 10:26 AM
350ztoronto's Avatar
350ztoronto
O Rly?
Old Dec 21, 2005 | 12:18 PM
MIAPLAYA's Avatar
MIAPLAYA
Old Dec 21, 2005 | 12:28 PM
toretto26's Avatar
toretto26
i'd say go wider with the tires
Old Dec 22, 2005 | 10:54 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by MIAPLAYA
Old Dec 22, 2005 | 11:09 AM
thawk408's Avatar
thawk408
Originally Posted by Wired 24/7
HAHA. Where are you guys finding these? They do these on my local car forum also.
Old Dec 22, 2005 | 11:38 AM
MIAPLAYA's Avatar
MIAPLAYA
Old Dec 22, 2005 | 12:31 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
All joking aside, eddie lee -
keep searching the forums, you'll find the common wheel sizes and offsets that people are using. The sizes and offsets you listed suck for the Z.
Old Dec 22, 2005 | 12:36 PM
thawk408's Avatar
thawk408
Its good for some track wheels tho. They will fit slicks nicely.
Old Dec 22, 2005 | 01:12 PM
Zexy's Avatar
Zexy
Won't fit w/ BBK and will tuck in too much.
Not the right offsets.
Old Dec 22, 2005 | 02:27 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Plus, if you have to buy spacers for your NEW wheels, you did something wrong.
I can see buying spacers for wheels you already own (like from your last car, transferred to the Z, you're trying to save some cash) but I cannot see buying spacers for new wheels.
Old Dec 22, 2005 | 02:44 PM
thawk408's Avatar
thawk408
Unless the wheels are a REALLY good deal.
Old Dec 22, 2005 | 11:17 PM
eddie lee's Avatar
eddie lee
Hey guys, Give me some good idea on wheel size and the best offset, remember that I perfer 18" and all four wheels the same size, so I can do the rotation! And forget about the subject on the spacer, the racing season in CA is coming up in 2 months!
Thank You.
Old Dec 22, 2005 | 11:47 PM
thawk408's Avatar
thawk408
I personally love the CCW classics in an 18x9.5 and around a 30+ offset. I would think you would need a pretty high offset to be able to fit the 9.5s in the front. You could also go with the Nismo rear wheels all the way around and they are an 18x9.5. This would allow you to put some 275 Hoosiers on there for some serious traction.
Old Dec 22, 2005 | 11:59 PM
eddie lee's Avatar
eddie lee
Which one is CCW CLASSICS?
Old Dec 23, 2005 | 01:12 AM
thawk408's Avatar
thawk408
The same wheels the Performance Nissan racecar use. In person they look hot! I am going to pick up a set of these for my track wheels. They use 17x9.5 front with 245s and 17x10.5 rear with 275s. Im not sure if I want to go with 17s or 18s, but I am almost possible that a 275 will fit on a 9.5 width.
