Advantages/Disadvantages of 17x7 All around?
Old Jan 11, 2006 | 06:25 AM
sq40's Avatar
sq40
Default Advantages/Disadvantages of 17x7 All around?
Forgive me if this has been covered before,
But are there any advantages or disadvantages to having a uniform 17x7 wheel/tire all around on the Z?
Old Jan 11, 2006 | 06:33 AM
mario60185's Avatar
mario60185
Chicago Realtor
dis: Its gonna look gay as all hell, and traction will suck
Old Jan 11, 2006 | 06:35 AM
Alberto's Avatar
Alberto
Cranky FI Owner
+1
Advantage-if you downgrade to a Civic, Celica, RSX later, you can put your weaksauce sized rims on
Old Jan 11, 2006 | 06:43 AM
sq40's Avatar
sq40
Ah..I was hoping to get a little better tracking in snow/rain with a narrow tire.. Bit if it will look that bad..
Advantage: weight.
Disadvantage: Same tire height will play hell with TSC and VDC. I think a rear tire such as 11 inches wide is overkill. On the other hand, 7 inches is not enough rubber on the road. Somewhere between is a happy medium.
Old Jan 11, 2006 | 06:56 AM
sq40's Avatar
sq40
Originally Posted by davidv
Advantage: weight.
1 inch less on the rear will make that much of a difference?
Old Jan 11, 2006 | 08:51 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Stock 17s are 7.5 front and 8.0 back with 225/235 summer tires on them, and they look a little small under such a wide car. How thin were you planning on going with the tires?
I think you would be better off finding a good all season tire on stock 17s than going with a narrower rim and tire combo. Sure thinner tires will cut though the water/snow but they may not have enough grip once they hit solid ground to be of much good in anything other than a straight line.
Chris
Old Jan 11, 2006 | 09:22 AM
sq40's Avatar
sq40
So a 17x8 all the way around might be a better setu for the ame size. I am also thinking about the ability to rotate the tires too. The Stock width looks OK to me.
A Staggered Set would probably be fine though.
I was thinking of a 215 or 225 Tire all arround.
Old Jan 11, 2006 | 02:13 PM
MarquisDeSam's Avatar
MarquisDeSam
17 8.5/9.5 will make your car fly. Sure they might look funny as hell, but with a lightweight forged, i.e. volk TE/CE or 5zigen fno1r, it will be worth its performance in gold. Traction depends on your tire width. go 245 275.
Old Jan 11, 2006 | 02:16 PM
sq40's Avatar
sq40
what is the max tire width to safely put on a 17x7 and a 17x8?
Old Jan 11, 2006 | 06:55 PM
Mr.Jadkowski's Avatar
Mr.Jadkowski
depends on the tire. There are people on this forum that have run 275 slicks (kumho V710s) on stock wheels (7.5" and 8"), but that's pretty extreme, and those tires have a very stiff face on them. I dunno if I'd go much wider than 245s on stock wheels.
Old Jan 11, 2006 | 08:01 PM
A_16's Avatar
A_16
i have 17x7 setup as a snow tire setup.....gets me around real good actually.
and now when there is no snow on the ground it gets wicked loose
Old Jan 12, 2006 | 07:04 AM
sq40's Avatar
sq40
Are you running All Season Tires or Snow tires?
mr. sparco
Aug 25, 2013 10:24 PM
Dissident
Dec 19, 2007 08:38 AM
pnutandgiz
Mar 8, 2006 03:26 PM
