Can someone explain to me the terms used for Tires?
Old Feb 2, 2006 | 04:45 PM
JCA0688's Avatar
JCA0688
Default Can someone explain to me the terms used for Tires?
Ex. Offset etc. I've tried searching and no good. Sorry if this comes off as dumbass post, but we're all here to learn..
Old Feb 2, 2006 | 04:47 PM
blasian's Avatar
blasian
Tires or wheels? Offset is for wheels. I know you've seen the +20, +33, etc... the lower the offset, the more the wheel sticks out. The higher, its the opposite.
Old Feb 2, 2006 | 04:50 PM
JCA0688's Avatar
JCA0688
What about staggered? I've read that somewhere.
Old Feb 2, 2006 | 05:26 PM
blasian's Avatar
blasian
I want to say that staggered is when you have a larger width size in the rear than the front. Like having 18x8.5" in the front and 18x9.5" in the rear. I believe that is what staggered means.
Old Feb 2, 2006 | 05:30 PM
DavesZ#3's Avatar
DavesZ#3
Here ya go - anything you could ever want to know about tires.....
http://www.tirerack.com/tires/tiretech/tiretech.jsp
Old Feb 2, 2006 | 05:32 PM
DavesZ#3's Avatar
DavesZ#3
Staggered, in the context of the Z is where the rear tires are a larger diameter than the front. Your 4 wheels are the same diameter and probably the same width. The tires on the other hand are different widths with the same "profile" so the wider rear tires are actually taller than the fronts.
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
