rim width...
Old Feb 19, 2006 | 10:20 AM
sleeperZ69's Avatar
sleeperZ69
Default rim width...
I'm looking into getting 19'' rims, but how wide of a rim should I get? I want the wheels to be perfectly flush with the rest of the body. I've read that 19x9.5 in the front and 19x10.5 in the rear look pretty flush except for the rear sticking out a tiny bit. Would 10'' in the rear make it look more flush?
What do you guys recommend?
Thanks
Old Feb 19, 2006 | 10:34 AM
Endless Shock's Avatar
Endless Shock
Smile
Its all about the proper offset... Looking at previous posts here is an example...
*** This is not my car its Volk350Z's ***
His old setup if is as follows... Volk LE's 19x9.5 +22 & 19x10.5 +22 with Toyo T1R's 255/35 & 285/35...
A few other things you want to check are alignment and fender rolling/cutting if you want your ride to sit like this...
Well I hope that helps out a little bit...
Old Feb 19, 2006 | 07:21 PM
How about researching one of the stickies about offset. That will give you an idea about the relationship between wheel size and its position inside the wheel well.
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
