Stock Brembo Kit for sale?
Old Feb 21, 2006 | 10:16 PM
ZZ33bOI's Avatar
ZZ33bOI
Default Stock Brembo Kit for sale?
I have a 03 Touring Z, I want to upgrade my brakes to maybe a Track brembo or 06 GT brembo's does anyone know where i can buy this kit? Im not hardcore, so I dont think I would need a 6 piston Kit nor a 14" rotors...even tho they will be nice to have. I dont think I have the money for them. Does anyone know where I should start this serach. Been looking through the Brakes/suspension but got no info. I like the stock Brembo set up, does anyone know where I can find a kit? or have the PART number? price will be great too, and pictures.
Thanks
Old Feb 21, 2006 | 10:20 PM
steela2110's Avatar
steela2110
Maybe you could give Ted a call at Scotts Performance in Santa Clara
Old Feb 21, 2006 | 10:25 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
to buy all new parts with stop tech rotors / lines.. fully discounted is more then it would cost to get a full 13" stop tech kit all around...
Old Feb 21, 2006 | 10:31 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
OEM parts are expensive. Brembos are rediculously expensive. You can find the performance nissan OEM parts website here
http://www.trademotion.com/partlocat...?siteid=214252
First of all, it's probably not worth it to buy USED brembo rotors or pads. So if you were to buy used, basically you'd just be buying used calipers and then buy replacement rotors / pads (and maybe SS lines). You will see that brembo parts are expensive as f0ck to replace, you would be better off buying a BBK most likely.
[edit]: Jason beat me to the punchline....................
Old Feb 22, 2006 | 08:34 AM
streetracer's Avatar
streetracer
Default Brembo
I found a set on a Track Mdl in a junker. The guy apparently hit something and damaged the front of the car but the brakes and Rays were intact. I did have to send one of the Rays to machine shop. Negotiating is key and try to go with someone they know. I went with the owners electrician and negotiated all for $1600 including Rays with tires and rotors. Also very important is the brake lines installation. I was left without brakes on the highway two times for improper installation. The calipers are a direct bolt on but the lines are not. The base has females and the Track has males. My solution and recomendation is to purchase sepparately a set of braided lines from Goodrige. Do not custom make them and do the same mistake I made. The guy did them too long and were rubbing on the rim, which obviously caused them to break.
Old Feb 22, 2006 | 08:46 AM
ZZ33bOI's Avatar
ZZ33bOI
thanks man that was the answer i was looking for!! anybody esle have the same situations?? tryin to upgrade there stock 03 to track brembo's...and the reason why im gon this route because my dad works for a wholesale distrabutor for brembo, endless, and etc etc...so I am able to get everything at wholesale..=o) and i also work for a shop too..hahaha i just want to see if anyone ever went this route that i was thinkin about doing...i am just doing my HW and gettin all my research done before i start taking everything apart!
Old Feb 22, 2006 | 09:44 AM
97supratt's Avatar
97supratt
I wonder if anybody would trade the 03-05 brembo brakes for my stock 06 enthusiast ones...
Old Feb 22, 2006 | 09:47 AM
Amiricanmade's Avatar
Amiricanmade
Thanks
If you end up selling the stock kit you have on right now...pleasssssssssse let me konw. ill buy!
JjL
East Canada
Jun 12, 2019 03:04 AM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
seagrasser
Oct 11, 2015 03:27 PM
juang20
Intake
Sep 7, 2015 05:37 PM
