A simple wheel upgrade
Old Feb 28, 2006 | 04:52 PM
gaz076's Avatar
gaz076
Question A simple wheel upgrade
I'm looking to do a simple upgrade by just replacing my 17" stock wheels on my Z (Enthusiast) with the same wheel size but wider. I'm looking at SSR GT-7 wheels that are 17x8.5. The offset of the front stock wheels is 30 and the offset of the stock rear wheels is 33. The offset on the SSR GT-7 is 35 front and rear. The big questions are 1) how will the tires fit in the wheel well and 2) is the offset ok so the wheels/tire maintain the current tire/body look?
The wheels will probably get Goodyear Eagle F1 GS-D3.
Any assistance would be appreciated.
Old Feb 28, 2006 | 06:12 PM
Kolia's Avatar
Kolia
8.5 wide is not a big upgrade. Any particular reason?
If it's to stay within factory standard, know the '06 Track has 18x9 and 19x10 wheels.
Old Feb 28, 2006 | 08:01 PM
Welcome.
Use one of the offset calculators above and compare the new wheels to your current ones. Then check the car with a tape to see if you will have any clearance problems.
I will caution against using the same size tires all around.
Obadabot
Jun 18, 2023 11:31 PM
