HRE Wheels Banned from VPR and IMSA events
probably old news but....
http://forums.audiworld.com/lrqc/msgs/41036.phtml
Interesting tid-bit. Talking to IMSA and Viper Racing League sterwards. found HRE's are banned ...
in both series due to too many failures.
NINE, yes NINE failures in one race weekend Vipers.
Apparently the PCA is on their way to banning HRE's as well.
The racers have always called them "Fools Fashion" and i thought that was a little rough until I started seeing them fail at track events and how easily they bend and corrode.
Then, after Leslie had problems with hers corroding and I spoke with one of the owners, I realized quickly they were WAY out of reality as to strength and design.
Wasn't really surprised that they were banned (was at the meeting), but was surprised at ALL the problems reported.
Unreal for such an expensive wheel.
Apparently tolerances are sooooo poor that the tires often rotate on the wheels themselves as the rims are often slightly too small.
Here is a pic I took a few years ago. The yellow grease mark HAD been aligned with the valve stem earlier in the day........
Originally Posted by Volk350Z
that's why most ppl don't race with stock wheels..
Would you please point me to the threads that confirms that MOST people buy aftermarket rims for this reason. I've seen many reasons for buying different rims.....looks....wider....lighter....better offsets...etc.......but I must have missed the spinning tire on rim reason.
Originally Posted by EnthuZ
Ummmmm, and what do you base that statement on?
The claims against HRE wheel failures on the track are false, and were unfortunately started as a rumor. If you read the links posted, you will ultimately find out that the failure was a Kinesis wheel, and measures were taken to remedy the problem. HRE wheels are not banned in any racing series.
Well......I spun my OEM Bridgestones on my OEM 17" Nissan rims many times at DE's too. So, OEM wheels need to be banned from tracking?
yes but you can still run aftermarket wheel with stock size and offset..
HRE also have this problem
http://www.6speedonline.com/forums/s...ad.php?t=41027
http://www.dtmpower.net/forum/showthread.php?t=147071
if you read on in those forums you will notice that the water retention issue in the rain is a characteristic of all reverse drop center wheels. the wheels with the flat lip (as opposed to the stepped lip) have the drop center in the rear where water can build up. this happens to hre, iforged, dpe, kinesis, etc.
