whats the largest wheel spacer for stock studs
Old Mar 21, 2006 | 08:50 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Default whats the largest wheel spacer for stock studs
whats the largest spacer that can be used with stock wheel studs,i just need to bring the wheels out a little farther.
Old Mar 21, 2006 | 08:52 AM
sq40's Avatar
sq40
From what I understand 5mm.
Old Mar 21, 2006 | 09:22 AM
kcobean's Avatar
kcobean
^^ +1. The HRE spacers come with extenders for the 10+mm packages if I recall. 5mm really doesn't gain you much width, unfortunately.
Old Mar 21, 2006 | 09:45 AM
John@Victory's Avatar
John@Victory
and 5mm only gives you about 2 turns on the lugs too... got a set sitting here now that i wont use cause i dont trust the 2 turns i get on the factory lugs
Old Mar 21, 2006 | 01:42 PM
Auto RnD's Avatar
Auto RnD
or if you'd like
you can run bolt on spacers...
https://my350z.com/forum/showthread.php?t=178451
they range from 10-30 mm
Old Mar 21, 2006 | 01:52 PM
John@Victory
are those the actual ones you are selling? if so why would i want to go with a 4 lug bolt pattern?
Old Mar 21, 2006 | 02:06 PM
Auto RnD's Avatar
Auto RnD
that is jus a generic representation as i have then for 4x100 4x114.3 5x100 and 5x114.3 =)
But yes those work great.. i've never had trouble with them and i do track that car.
Old Mar 21, 2006 | 02:17 PM
pope's Avatar
pope
Here is an actual pic from the set I just installed. Great spacers...
installed with G35 rays
installed with Z track rays
AutoRND...
Is that Dana or Josh??? or someone else?
Old Mar 22, 2006 | 03:47 PM
Auto RnD's Avatar
Auto RnD
this is josh =) hehehe
Old Mar 22, 2006 | 04:11 PM
pope's Avatar
pope
cool, i might send a couple parts i need quotes on. i will pm you later.
Old Mar 22, 2006 | 05:15 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Nice spacers....
Old Mar 22, 2006 | 09:20 PM
Volk350Z's Avatar
Volk350Z
Master
those spacer are use on alot of D1GP cars...
Old Mar 23, 2006 | 09:09 AM
superchargedg
Damn Noobs
thanks gentlemen i think ill be calling autornd soon.
Old Mar 23, 2006 | 09:55 AM
[]V[]addog's Avatar
[]V[]addog
DAMN! that looks amazin. I didnt realize Grays could look that good on the Z. I guess slammin the car helps too.
Nice set up
koodos
Old Mar 23, 2006 | 09:56 AM
[]V[]addog's Avatar
[]V[]addog
first step
i need to start looking for a set of rays!
second step
get some spacers
what's a good size tire to put on the rays?
Old Mar 23, 2006 | 12:54 PM
Auto RnD's Avatar
Auto RnD
15mm front and 20mm rear seems to be the popular sizing for wheel spacers on the track or g35 wheels
Old Mar 23, 2006 | 01:17 PM
pope's Avatar
pope
+1 i really like this setup. I think the 25mm is just a little too much on the rear. you could prob go 20 on the front if you wanted.
Old Mar 23, 2006 | 02:10 PM
spacemn_spiff's Avatar
spacemn_spiff
How heavy are these spacers? What material are they? Al 6061 or SS 302?
Old Mar 23, 2006 | 02:14 PM
pope's Avatar
pope
see below
Old Mar 23, 2006 | 02:15 PM
pope's Avatar
pope
not too heavy. I couldnt tell you what material though because everything on and in the box is in japanese (with the exception of about 5 words). Maybe Josh can tell you that.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
