Rear wheel bolt
on
I was driving home from work tonight and the car started making a wierd noise and then all of the sudden the rear end got loose. I pulled over to the side of the road and drove slowly while I looked at my rear wheel and I noticed it was wobbling back and forth. I stoped the car and further investigated and I found that one of the wheel bolts broke off and the other 4lug nuts were loose.
What do you have to do to replace a wheel bolt? And how much does it cost?
Performance Nissan
Performance Nissan
$2.37 plus ship for the hub bolt...
http://performancenissanparts.com/ca...roducts_id=368
$120 for labor if you pay a shop...
$120 labor?! Damn, do it yourself! I swapped out all my studs with longer ones for spacers myself and it was a breeze. For a broken stud, all you need is a hammer, some penetrating lube, a good sized punch and an old lug nut you can cut the end off of with a dremel to make it open ended. Just jack up that corner, remove the wheel, brake caliper and rotor (leave E-brake off), spray penetrating lube on the broken stud and pound it out of the hub with the hammer and punch. Then just slip the new stud in from the rear (plenty of room; hub does not need to be removed) and pull it into the hub by tightening down the cut lug nut onto it with a box end or crescent wrench. Viola, you're done; put the rotor and caliper back on and remount the wheel. 20 min job.
Can you get enough pressure to seat it using just a lug nut without threading the bolt? I thought there was a special clamp made for this?
350Z_Al
10-29-2020 07:44 PM
