Spacers
Old Apr 3, 2006 | 10:22 PM
josephchihweilu's Avatar
josephchihweilu
Default Spacers
I'm currently running Volk SF-Challenges 8.5 front and 9.5 rear w/ Offsets 21 and 23 i believe. I want to get the wheels more flush with my car and I was looking at Kic's Project Spacers but I'm unsure of what size spacer to get. Can any of you help me out with the calculations? Thanks
Old Apr 3, 2006 | 10:32 PM
pope's Avatar
pope
you can get an idea by just putting a ruler (with mm increments) against the tire wall and see how many MM it would take to get them out to where you think it will look okay. make sure to take into consideration the fenders (you might need to roll them)
Old Aug 31, 2007 | 11:56 AM
Crom's Avatar
Crom
Bump for same question...just ordered 15mm spacers all around for exact same setup....May have to adjust ride hieght a bit w/ the tien flex - hopefully won't have to roll the fenders.
Old Sep 6, 2007 | 12:42 PM
Crom's Avatar
Crom
Any thoughts on this... kind of overwhelmed w/ all the spacer threads, just looking for some quick advice...thanks in advance.
Old Sep 6, 2007 | 12:59 PM
1nate7's Avatar
1nate7
I'd go with 10mm. 15mm are a little easier to find but you will have to roll your fenders unless you are running stretched tires and a lot of negative camber.
Old Sep 6, 2007 | 01:03 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
I put 20mm Project kics on my rears. The wheels are 10" width with +37mm offsets. My fenders are rolled, no rubbing. Camber is running at -1.6 degrees.
Old Sep 6, 2007 | 01:26 PM
Crom's Avatar
Crom
Sweet...thanks, I'm rolling my fenders hopefully this weekend..will try out the15's on the rear, I have ichiba 20's as well but i think that might be over doing it a bit....
Old Sep 6, 2007 | 01:59 PM
noodleman's Avatar
noodleman
where did you guys order the project kics spacers? I'm looking into getting a set! Thanks!
Old Sep 6, 2007 | 04:23 PM
VIZAGE's Avatar
VIZAGE
+1. The last I heard, they were backed ordered like crazy. But that's been about three weeks now.
Old Sep 7, 2007 | 06:45 AM
rcntype's Avatar
rcntype
Why dont you just measure how much clearance from the fender now? That will tell you how wide of a spacer you can run.
Old Sep 7, 2007 | 07:03 AM
cheshirecat79's Avatar
cheshirecat79
When you meaure your wheel gap to determine how large of a spacer you need, I'd suggest measuring towards the top of the fender rather than the bottom just as a rule.
Our fenders are not even- the top sticks out a little more than the bottom. If you measure from the bottom you'll still have a gap on the top.
I personally think that having the wheels flush at the top so that they flare out a tiny bit towards the bottom of the fender is a great look.
Old Sep 7, 2007 | 08:45 AM
Crom's Avatar
Crom
- Thats pretty much what I did and it came out like 3/4 of an inch tucked in.
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
