Pix of Toyo T1-R in 255/35/19 and 285/35/19?
Old Jun 2, 2006 | 08:41 AM
  #41
Will Pwr's Avatar
Will Pwr
Originally Posted by plastiketa
From what I've heard, the paint can still crack even with someone that knows what they're doing. Its just taking the chance I guess. I would prefer to shave the fender instead since cracking the paint is least likely. I saw Rick @ Status' fenders and it look fine. He needs to take a drumel to to clean it up more, but it looks like a nice job.
Will Pwr- But what metal is exposed from shaving that wouldnt exposed already??
Basically the material around the whole inner fender is painted from the factory..if you shave away it will cut into the edge and shave away just that area of the paint. Its not a big deal, but just either touch up paint that area or use some sort of clear to coat it
Old Jun 2, 2006 | 09:57 AM
  #42
drumma022's Avatar
drumma022
Roll the fender and add in some camber and you won't have to worry about rubbing. Before I sold my last set of tires I had a 275/30on a x10.5+11. Now I have a 275/35 on a x10.5 +17 and have plenty of room for more tire.
I think rubbing should be the least of your worries as long as you can make a few adjustments to work wround it! Here is a picture of my 19x9.5 +22 with a 5mm spacer and a 245/35 front and a 19x10.5 +22 with a 5mm spacer and a 275/35 rear.
I am planning on doing a 255/35 front on the next set of tires and keeping the 275/35 rear. I think I will be getting a 10mm spacer as well to push the limits
Attached Thumbnails Pix of Toyo T1-R in 255/35/19 and 285/35/19?-te371.jpg
Old Jun 2, 2006 | 09:59 AM
  #43
BhashaZ's Avatar
BhashaZ
Now I think I'm going to go with 295/30...if I roll the fenders, how much negative camber would I have to run? I'm only dropped on Hotckis...
Old Jun 3, 2006 | 09:57 AM
  #44
drumma022's Avatar
drumma022
I am not sure exactly how much camber you would need, however you can tailor that to what your tire needs are. VRT has done well witha 285/30 front and a 315/30 rear!!
Old Jun 7, 2006 | 12:28 AM
  #45
response's Avatar
response
drumma022,
Hey, just wondering what type of 5mm spacers are you using? Also, is it necessary to use extended wheel studs?
Old Jun 7, 2006 | 02:14 AM
  #46
NiSmO D1X's Avatar
NiSmO D1X
heres my old car with running 255/285
Old Jun 7, 2006 | 09:38 AM
  #47
drumma022's Avatar
drumma022
The wheel studs are some generic brand we have at the shop here. I would say 5mm is the most you could go on the stock studs since there are only a few threads available to pull down onto.
Old Jun 14, 2006 | 12:35 PM
  #48
3five0_GT's Avatar
3five0_GT
Take a look at Nitrouz wheels.
https://my350z.com/forum/showthread....16#post2432616
Old Jun 14, 2006 | 12:38 PM
  #49
3five0_GT's Avatar
3five0_GT
Are those 18's? There is awful a lot of room in the rear. Is the car lowered?
Take a look at these.(350Z member: Nitrouz) F19x9.5 +17 & 19x10.5 +18
Old Jun 15, 2006 | 08:43 AM
  #50
NiSmO D1X's Avatar
NiSmO D1X
yea i couldn't lower the car do to the kit being so low. It was a daily driver so, anylower i would have been mowing the lawn
Old Jun 15, 2006 | 10:45 AM
  #51
3five0_GT's Avatar
3five0_GT
I think if you go 19's then the car will be raised a little.
Old Jun 15, 2006 | 11:17 AM
  #52
LiLxDooD's Avatar
LiLxDooD
i think those are 19s
Old Jun 15, 2006 | 12:12 PM
  #53
NiSmO D1X's Avatar
NiSmO D1X
yes he's correct, they are 19's.
bcoffee20
Nov 19, 2015 06:39 PM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
Mr Fairlady
Mar 6, 2003 05:24 PM
toothlessracer
Jan 12, 2003 08:01 PM
