Spacers
Old Apr 6, 2006 | 05:11 PM
drewby's Avatar
drewby
Arrow Spacers
Hi, as anyone fitted spacers on the rear of there Z, how thick can i go 15 - 20 - 25 mm, uk. gt model. with rays on. cheers. D
Old Apr 6, 2006 | 07:17 PM
ZlleH's Avatar
ZlleH
If it is stock tires, get the H&R 25mm spacer for the back wheels. Right now I am contempleting 15mm for the front wheels...
PS: The 25mm spacer mod at the rear tires is one of the best looks mod I have done, the car looks so aggressive. The rear tire doesn't look like it is hiding in a cave now. I definately recommend the spacer.
Old Apr 6, 2006 | 11:58 PM
aren21's Avatar
aren21
Im guessing your car isnt lowered (I read your sig) I wanted to know if your car rubs at all with the spacers. I thought about doing this on my Z(stock 18'' wheels), but didnt know if it would rub with or witout lowering. Do you have any pics??? I would like to see how it looks, I know what you mean by the tire hiding, its tucked in way too much. Thanks.
Old Apr 7, 2006 | 12:32 AM
New2350's Avatar
New2350
Pics?
Old Apr 7, 2006 | 12:54 AM
Chad68's Avatar
Chad68
15MM spacers on the rear with anniversary wheels rules!!!!
Old Apr 7, 2006 | 05:00 AM
AndyS's Avatar
AndyS
I have 25mm Hubcentric H&R spacers on the rear w/ 19" Ray's G35 wheels, car is not lowered. IMO I would go w/ 20mm, the 25 looks a little too far out.
Old Apr 7, 2006 | 06:23 AM
MustGoFastR's Avatar
MustGoFastR
Agreed, 25 looks too far out. 20 will put it flush. I have 15 on my rear Rays wheels and 10 in the front, which pushes them out to within 1mm or so of where the Nismo wheels sit. Looks and handles great.
Old Apr 7, 2006 | 07:08 AM
ZlleH's Avatar
ZlleH
It might be because the G35c has different body dementions...
With my H&R 25mm spacer in the rear, I still think I could use another 5mm to make it perfectly flush.
For the original poster, Whatever brand of spacer you get, make sure they are Hubcentric.
Old Apr 7, 2006 | 07:12 AM
ZlleH's Avatar
ZlleH
No, it isn't lowered, but my friend has the same spacer and he had his car lowered 0.7 inches and it was good. I will be lowering it the same measurements at a later date.
I will be installing a painted lip this weekend and will see how much clearance I have before deciding on lowering the car.
After I put the lip on and take some more recent pics, I will take closer pics of the rear wheels to show you how close the spacer makes the rear wheel flush to the body.
Old Apr 7, 2006 | 08:29 AM
sry110's Avatar
sry110
I have a 2006 Z (with the standard 35th anniversary wheels) and have been considering some wheel spacers to push the wheels out, but I thought I remember reading that using spacers will detriment the quality/durability of the car's suspension? What I didn't read is the reason why. Can anyone shed some light on that? Also by using spacers, I would think you have less stud sticking out through the wheel...the original stud length minus the spacer thickness, to be exact. Is it really safe to have the lugnuts holding the wheel on with that much less thread engagement?
I'm trying to convince myself that I won't have any problems with this relatively inexpensive mod. It sure is a whole lot cheaper than buying new wheels, and after the car is lowered it should look badass. What's everyone's opinions on these issues?
-Steve
Old Apr 7, 2006 | 08:45 AM
superchargedg's Avatar
superchargedg
Damn Noobs
^^^ get the kics spacers,they are on the wheel and tire section,they bolt up to your stock studs.
Old Apr 7, 2006 | 08:53 AM
MustGoFastR
-Steve
Putting spacers on your wheels is no different than getting rims with a more agresive offset. As mentioned above, the most important thing is that you get hubcentric spacers like those from H&R or Eibach. There are two types of spacers, one comes with longer studs to replace your stock ones and the other comes with studs built into it and nuts that secure the spacer to the hub using the stock lugs.
Old Apr 7, 2006 | 09:28 AM
ZlleH's Avatar
ZlleH
This is what my spacer looks like:
-Steve
Old Apr 7, 2006 | 09:53 AM
sry110's Avatar
sry110
Ahhhhh, I see. Makes sense now.
Old Apr 7, 2006 | 12:32 PM
VenomZ's Avatar
VenomZ
I think after 15mm they are considered adapters.
I had Art at motorsport technology custom make mine. 25mm in the front, 35mm in the back(yes for a widebody)
Price was awesome and they are hubcentric on both sides. Their # is 909-514-0091 if anyone wants to go the custom route
Old Apr 7, 2006 | 03:44 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Spacers are sorta a band-aid solution compared to just getting wheels with the offsets you want.
There's nothing wrong with getting spacers, but there's also no comparison with getting wheels that fit the way you want.
Old Apr 7, 2006 | 04:06 PM
MustGoFastR
I think everybodu knows that. Not everyone has the cash to throw at a degent set of rims, though and spacers can make a marked improvement for a couple hundred bucks.
Old Apr 7, 2006 | 07:48 PM
kpiskin's Avatar
kpiskin
So what is the answer? I also have 18" Track Rays and want to push them out but not too far. So far it sounds like 15mm for the front and 20mm for the rear look best, is that correct?
Old Apr 7, 2006 | 08:16 PM
MustGoFastR
For pure looks, yeas, that's probably what you want. With my setup, 10mm F, 15mm R, it looks good and I'm happy with it, but they could go out a little more. I wanted mine to sit where the Nismo rims do to go with something that was designed with handling in mind and not pure looks. Not to say that going out more will be worse for that, but I just wanted to be safe.
Old Apr 7, 2006 | 11:38 PM
mprasadjr's Avatar
mprasadjr
I have 30mm on all four and is lowered an inch with a greddy front lip and nismo sides. Compliments never stop
