Buy tires tomorrow need help please!!!
Old Apr 12, 2006 | 09:04 PM
TheLza23's Avatar
TheLza23
Default Buy tires tomorrow need help please!!!
I wanted to get wider tire in the rear (245/45/17) will this setup work if i leave the front tires the same. THX!!!
Old Apr 13, 2006 | 03:24 AM
Kolia's Avatar
Kolia
Just keep the overall diameter the same as the tire you're replacing.
Old Apr 13, 2006 | 09:00 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
245/45R17 is actually smaller in diameter than the stock front tires by .09" and could cause "Slip" light issues if your car has TCS/VDC.
The common replacement size for the 17s is 255/45R17, 8" is the smallest rim size recommended for this size by most tire manufacturers.
By the way, 245/45R17 is the common front tire replacement, also the front 7.5" rim is the smallest size recommended for this tire by most manufacturers.
Chris
350Z_Al
Oct 29, 2020 07:44 PM
