Axis Matrix Rims/ TCS issue
Old Apr 19, 2006 | 12:50 PM
Kevd007's Avatar
Kevd007
Default Axis Matrix Rims/ TCS issue
Does anyone have traction control problems with large rims and tires? I just bought the Axis MAtrix (f) 20x9 and (r) 20x10.5, Tires: Falken grb-fk451 255/35/20zr, 285/30/20zr, and they look and drive great. But sometimes when taking a sweeping turn or making a quick turn the traction control activates more so now then with the stock rims and tires. It seems to stay on longer and come on when there is no real reason. Does anyone else experience this or issues with traction control?
04 touring 350z auto w/ manual shift
Thanks for any input
Old Apr 19, 2006 | 02:39 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
It's the tires, same complaint at this thread here
https://my350z.com/forum/showthread....ght=slip+light
and here
Your backs need to be at least .5" taller than your fronts
In your setup, the backs are .3" shorter than the fronts
A 255/30R20 on the fronts should fix this.
Discount tire has a calculator
http://www.discounttire.com/dtcs/infoTireMath.dos
you can check the numbers with, just put the front tire in the "old" slot and the back in the "new" slot and check the overall diameter. If it's less than .5" it could be trouble.
Chris
Old Apr 20, 2006 | 04:56 AM
Kevd007's Avatar
Kevd007
Smile Thanks Chris, kcobean
You both basically gave the same remedy. Thanks, now I just have to get the dealer or the manufacturer to replace them....
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
