Wheels spacers
Old May 6, 2006 | 10:19 PM
6swhite350z's Avatar
6swhite350z
why did nissan make the front look flush, but the rear look like its in? ..
same can be said about mustangs..
Old May 7, 2006 | 03:48 PM
sq40's Avatar
sq40
I am not sure.. Good Question.
Old May 8, 2006 | 10:54 AM
Auto RnD's Avatar
Auto RnD
wow
i should keep up on the forum on weekends hehehe
anywho..
Nissan uses approx same offset front and rear
where as the rear is slightly more agressive in term of width ie.. slightly wider.
hence you need to run a bigger spacer in the back than in the front.
Now.. with spacers and hub centric rings..
the hub centric rings just make sure the spacer is back to the oe size hub bore.. IF you purcahse aftermarket wheels you would still need to get hub rings for those wheels.
I personally like project kics.
they are easy to install and less hassle..
Especialy compared to the hnr..
Also i drift and auto-x with the spacers on the car all the time.
I have full faith in them.. Just beware of cheaper (ebay) items.
Old May 8, 2006 | 05:37 PM
[]V[]addog's Avatar
[]V[]addog
thx for all the good info guys
Old Jun 9, 2006 | 11:35 AM
ZWildZ's Avatar
ZWildZ
What would you guys recommend for an '06 350z running 19" G35 coupe rims?
Old Jun 22, 2006 | 08:24 PM
ichibausa's Avatar
ichibausa
Here you the link for the wheel spacers, huge selections!
https://my350z.com/forum/showthread....ghlight=ichiba
Old Jun 23, 2006 | 08:14 AM
2005ssm's Avatar
2005ssm
Default 25mm TRAK spacers front & rear
I'm running 25mm H&R TRAK spacers front and rear on my 06 with the factory 18" wheels at stock height. Works fine and looks much better in my opinion. I imagine that the vehicle could still be lowered conservatively (approx 1" frnt and rear). However, I do not believe that the camber could be adjusted back to spec after lowering without rubbing unless the rear fenders were rolled or cut.
Just my 2 cents...
Terry
Old Jun 23, 2006 | 01:49 PM
RNL323's Avatar
RNL323
Mod My Ride
The question is, can you find the KICS in stock?
Been searching for 15MM forever and all are back ordered. Tried Evasive and AutoRnD....
PM if anyone has found them any where else in stock.
Old Jun 24, 2006 | 07:13 PM
FairLadeeeZ's Avatar
FairLadeeeZ
I have some for sale!
https://my350z.com/forum/showthread.php?t=199549
Obadabot
Jun 18, 2023 11:31 PM
