will 285/35/19 work on stock grand touring wheels?
Old May 12, 2006 | 10:05 PM
superppwZ33's Avatar
superppwZ33
Default will 285/35/19 work on stock grand touring wheels?
2006 grand touring
the wheel are 19 x 10
will the 285/35/19 work
as far as rubbing?
thanx
sean
Old May 13, 2006 | 09:20 AM
What width are the OEM tires?
Old May 13, 2006 | 09:28 AM
superppwZ33
Old May 13, 2006 | 09:34 AM
Originally Posted by airtrackk
265/35/19
I recommend the OEM width plus minus 20mm. Go for it.
Old May 13, 2006 | 06:23 PM
superppwZ33
thanx
Old May 13, 2006 | 06:27 PM
InSaNeZ's Avatar
InSaNeZ
Yes it'll work and will look a lot nicer than the 265.
Old May 13, 2006 | 06:34 PM
superppwZ33
well i somehow managed to drive over a fat screw that entered the tire from bottom and penetrated the sidewall....so needless to say the tire was gone
none of the local shops had the potenza reo50a in stock
but i found someone that had a conti sport contact 2 in the same size in stock, the tread is very similar, so i went for it.
but i'm def. changing to 285/35/19 when it's time to change tires
the 265's look stretched anyways
Old May 13, 2006 | 06:40 PM
usmanasif's Avatar
usmanasif
Will work perfectly and look fantastic. That is the same setup I have on my GTc as of two days ago. 285/35/19 rear and 255/40/18 front. No VDC issues. No rubbing concerns.
But do keep in mind that your speedo reading will be slightly off. Also, the brand of tire you choose will also affect rubbing. E.g. BFG KDW2 is a chunky tire while Toyo Proxes are not. I went with the latter.
Old May 13, 2006 | 08:30 PM
superppwZ33
for a second i thought you meant gtc as in volk gtc's
is there anyway you can post close up shots of the rims with the new tires on
thanx a bunch in advance
sean
Old May 15, 2006 | 09:01 AM
Chad68's Avatar
Chad68
A 285/30 will keep your overall diameter closer to stock, hence your speedo will be more accurate than a 35 series
Old May 15, 2006 | 07:39 PM
usmanasif's Avatar
usmanasif
sean
Car is at the bodyshop right now. Will take pictures when it comes back at the end of this week
Old May 15, 2006 | 07:53 PM
usmanasif's Avatar
usmanasif
No it won't
With an 80.8" circumference, a 285/35 rear tire is 2.1% slower than stock, so when speedo shows 60mph, I am actually doing 61.3mph.
With an 84.4" circumferance, a 285/30 rear tire is 2.2% faster than stock, so when speedo shows 60mph, the car would actually be doing 58.7mph.
Besides, VDC will not like the 285/30 nearly as much as it likes 285/35, even if the front sidewall is reduced by 5mm as well. The reason it works fantastically with my 285r 255f setup is because that combo yields nearly the exact same size ratio of front/rear as OEM does. It is only off by 0.001. Yes, I built an entire Excel spreadsheet around tire selection a few weeks ago with a half a dozen different sizes to see what combo should work best and to test the advice of folks on my thread on the same topic
Old May 15, 2006 | 08:30 PM
superppwZ33
can't wait to see it
tell em to hurry up
Old May 17, 2006 | 12:53 AM
Chad68's Avatar
Chad68
No it won't
That's weird because moving up from 224/45/18's and 245/45/18's to 245/40/18's and 265/40/18's keeps the overall diameter almost the same as stock sizes.
Wonder why it's so much different moving up from 265/35/19's to 285/30/19's.
Trippy..
Old May 24, 2006 | 10:07 PM
superppwZ33
any pix yet
Old Jun 4, 2006 | 04:51 PM
usmanasif's Avatar
usmanasif
Sorry airtrackk! I got a bit sidelined since your PM. A mod had also PM'd me requesting tire/wheel pics, so here they are from various angles. Hope this helps!
As my sig suggests, fronts are 255/40 on OEM GT 18x9 wheels and rears are 285/35 on OEM GT 19x10 wheels. Toyo Proxes T1R.
The great offset of these wheels is what truly makes this rear tire size look good.
Old Jun 4, 2006 | 06:57 PM
superppwZ33
AWESOME
the tires look perfect with the wheels
thanx for posting the pix
the rest of the mods look great too
Old Jun 4, 2006 | 08:50 PM
usmanasif's Avatar
usmanasif
Thanks, and you're welcome. I'm glad Nissan went with the staggered setup for GTc and Track. Volks certainly do rule!
Old Jun 5, 2006 | 09:51 AM
Demon Z's Avatar
Demon Z
Just going by your sig, I presume you're at stock ride height, usmanasif? Damn, that's smooth.
Old Jun 5, 2006 | 11:26 AM
usmanasif's Avatar
usmanasif
Yes, it is stock. The slightly-larger-than-OEM diameter of these two tire sizes makes it look as though the car is lowered...plus the 19s themselves give that illusion. I was asked which coilovers I had at our most recent local meet!
m_0g
Jun 3, 2021 10:05 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Shane86
Sep 17, 2015 05:33 PM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
