which combo would you use
Old May 13, 2006 | 09:48 AM
mattduke1's Avatar
mattduke1
Default which combo would you use
I've decided to put 245/40's on the front. For the rear would you guys run 245/45's or 255/45's. These are for the stock Anniv. rims which are 18x8. Does anyone run these combinations presently?
Old May 13, 2006 | 11:18 AM
1nate7's Avatar
1nate7
I ran the 245/40, 255/45 combo and wouldn't do it again. IMO the sidewall of the rear tires looks too much bigger than the front this way. I would run either 245/45 or 255/40 in the back.
Old May 13, 2006 | 11:27 AM
3FITTTY's Avatar
3FITTTY
Old May 13, 2006 | 12:25 PM
mattduke1's Avatar
mattduke1
Thanks guys for your response. I've seen at Tirerack and other places that the 255/40 size is recommended for at least an 8.5 rim.
Let's say I wanted to run 255/45's for the rear, how would 245/45's be for the fronts?
Old May 13, 2006 | 02:27 PM
MoodDude's Avatar
MoodDude
255/40 WILL fit on a 8" wheel! Don't do the 45's, it will look like truck tires!
Old May 13, 2006 | 06:57 PM
mattduke1's Avatar
mattduke1
man, I've been reading the tire threads on all of the Z forums today and it looks like with these rims, you don't have a whole lot of options other than the stock set-up. The possibilities for the fronts seem to be the stock 225/45, 235/40-45, 245/40-45 and the rears seem to be the stock 245/45 or 255/40-45.
Would anyone like to give a suggestion of what they feel the best combo would be? I would really appreciate it.
May 12, 2016 07:42 PM
juang20
Intake
Sep 7, 2015 05:37 PM
NiTr0u5oXiDe
Mar 9, 2003 06:30 PM
zland
Jan 24, 2003 04:58 PM
