What is the optimal size and width wheel for track/road course
Anyone know what is the optimum (or at least a “good”) size for wheels and tires for track/road course use? What size and width? And what would be some examples of wheels/tires in those sizes? Thanks
wider tires = wider footprints = better traction
bigger sidewall = more air = more comfort
more sipes = more cuts in the tires = better traction in wet condition, also faster at releasing heat
bald tires are very good for traction on dry roads, hence the race track...but will f*ck u over in wet weather...
i too want to know if anyone has a real answer.
best motoring international compared a 35th anniversary vs a version st. the wider rim provided better stability and less oversteer.
i want to know what rim and tire sizes will give the Z the best performance and what the different characteristic of each choice will be. i.e. acceleration, over/understeer, etc.
I'm using 18x9.5 +22 with 275/35/18 for both front and rear. I've found this setup to be well balanced but I think the gearing for tighter more technical courses isn't quite up to par so I'm thinking about going to a set of 17x9.5 with 275/40/18 front and rear.
Your final choice will also depend on the current and future setup you intend to run and of course your budget.
I do HPDE of full road courses. My track only wheel combo is:
5Zigen FN01R-C 17x9.0 +35 w/ 255/40R17 Toyo RA1 (front)
5Zigen FN01R-C 17x10.0 +35 w/ 275/40R17 Toyo RA1 (rear)
It’s a bit too much grip for a stock suspension though.
I’ve had fun with the OEM Track wheels with 235/40R18 (front) and 255/40R18 (rear) Falken Azenis RT-615 last year. That car was pretty well balanced and they served as a good dual use Street/Track setup.
Smaller diameter wheels will generally be lighter, so don't bother with 19's. 17" or 18" wheels will be fine. Honestly, I wouldn't worry a whole lot about the exact width, as long as it's in the general ballpark. You can dial in understeer/oversteer balance with careful adjusting of tire pressure. Just get a lot of trackday seat time under your belt. By the time you're up in the advanced group, you might get some idea of your own preferences -- whether you'd like a shorter sidewall for a crisper turn-in, or a slightly narrower rear tire so you can throttle-steer more easily...but for now, just get in the car and drive.
--Dan
Mach V
Fast350.com
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
