Volk GT-S thread
Old Jan 22, 2013 | 08:17 PM
  #1081
Pete5150's Avatar
Pete5150
Default Nice
It's that ring that holds the pressure sensor that keeps breaking off. Although that brand seems like it's got more metal around that ring, making it a little sturdier. Should I go with those or drill. Opinions?
Old Jan 22, 2013 | 08:27 PM
  #1082
Pete5150's Avatar
Pete5150
This is what I have now
Old Jan 22, 2013 | 08:34 PM
  #1083
805350z's Avatar
805350z
Try what i sent you before you drill into expensive wheels.
Old Jan 23, 2013 | 10:25 AM
  #1084
beezee's Avatar
beezee
the holes are drilled in the center right behind the spokes if you decide to go ahead with that. i will not advise that. too expensive to mess up and would rather live without tpms if i were in your situation
Old Jan 23, 2013 | 10:32 AM
  #1085
abarclay's Avatar
abarclay
+1 to iforged, I used them when I had GT-S and never had a problem.
Old Jan 23, 2013 | 12:19 PM
  #1086
Pete5150's Avatar
Pete5150
I appreciate the feedback, I ordered from Iforged today! Those look way more beefy than the crap I'm using now. This should be able to handle the speed better. Thanks again!
Old Jan 23, 2013 | 02:01 PM
  #1087
kevincat's Avatar
kevincat
heres mine 19x10.5 all around.
also looking to sell it
Old Feb 1, 2013 | 12:37 AM
  #1088
XM 1's Avatar
Default Question about refurbishing Volk GT-S's
so i'm fed up with the look of my Volk GT-S rims...and since they don't fit the new "style" of my car i want to change the color of the spokes.
never done this before so it would be nice to know some hints
so this is how the car sits at the moment
i really don't dig the rmc finish on the gt-s anymore...and since the day i saw a DB Z with gloss black volk gt-s i really want to change the color on mine.
but now on to the questions. first would be can i just unscrew the spokes while the tires are on? or do i have to get the tires of the wheels?
then the next one would be should i powder coat them or paint them? i really want a special black metallic (something that stands out) so painting the spokes would be the best (maybe!?!?).
with this rmc finish on the spokes, should i sand blast them before paint/powder coating?
and last but not least what bolts should i use to bolt the refurbished spokes back on? i heard of several companies offering bolts for volk wheels, but i'm not sure which to choose?
Old Feb 1, 2013 | 01:05 AM
  #1089
SR71's Avatar
SR71
Lead Super Moderator
Remove tires from wheels then disassemble them, tires aren't perfectly round and with out any center support they will distort the barrel, even with out air in them the bead rings are still strong enough to warp them. Also number the barrel 1,2,3,4 and the same for each face that goes to each barrel, this way they all go back in the same order they were built from the factory. Every wheel is a little different so when they are made they are trued a little after final assembly for the best roll. If the order gets mixed up they can develop a un-true roll to them as if they are bent or out of round. The easiest way to do this is just put some tape on the barrel and number it, then on the center part of the wheel on the back side around where the lug holes are take a nail counter sinker punch tool and put a little ding, 1 for 1 wheel 2 on the next and so on. This way you can get full paint coverage without having to worry about paint covering your numbers. As far as paint goes, who ever is going to spray or PC them they should take care of stripping them as well. Paint will be fine and you can always paint them for the color you want and PC them with clear for the best of both worlds. Bolts can be reused 1 time and still be OK, after that then you should replace for safety reasons.
Old Feb 1, 2013 | 02:50 AM
  #1090
Cux350z's Avatar
Cux350z
hatersgonnahate
sell them.
do not destroy the RARE rmc finish.
buy someones black gt-s
Old Feb 1, 2013 | 03:03 AM
  #1091
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
^^^ agreed.
Old Feb 1, 2013 | 07:19 AM
  #1092
Esser's Avatar
Esser
I think they look amazing on the car now
Old Feb 1, 2013 | 08:57 AM
  #1093
terrasmak's Avatar
Probably just trade them, many other Volk owners will be interested in changing up their looks.
Old Feb 1, 2013 | 10:25 AM
  #1094
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
If you really want to refinish them you can definitely have the faces removed and redone. That finish looks pretty cool though! There are lots of places that can refinish them, like Wheelflip.
Old Feb 1, 2013 | 01:53 PM
  #1095
Waiz's Avatar
Waiz
The added value of the RMC finish compared to what you will get them repainted will not be noticeable.
I would just have them repainted whatever color you want (plenty of examples in this thread) and let the wheel painter take care of taking them apart and having them powdercoated.
My NISMO's are painted and like the finish better than a powdercoat but the more durable option is to get them powdercoated
Old Feb 1, 2013 | 01:57 PM
  #1096
Bmurray350z's Avatar
Bmurray350z
It looks good how it is.. I do think you need a spoiler or some sort though.
Old Feb 6, 2013 | 12:57 AM
  #1097
XM 1's Avatar
well guys since money is thight at the moment i can´t afford to remove the tires (they are pretty old,but not worn....so if i remove them i´ll def. buy some new tires)..so i think i´ll stay with the setup a bit longer
@bmurray350z: i have a ing´s lx sport wing at home...but still undecieded if it fits the look
Old Feb 6, 2013 | 04:33 AM
  #1098
Bmurray350z
I think a Blitzz Spoiler would look good
Old Mar 8, 2013 | 08:19 AM
  #1099
RedLeader's Avatar
RedLeader
Is Rick at Status still around? I need my GT-Cs refinished....
Old May 29, 2013 | 02:19 AM
  #1100
angelo350z's Avatar
angelo350z
Is it true that the GT-S in 19x9.5 and 19x10.5 sizes now only come in +28 offsets? That's what I was told by a vendor on this forum . Has anyone heard of this?
