Can I use stock lugnuts with NISMO's ?
Old May 20, 2006 | 08:47 PM
socalkend's Avatar
socalkend
Default Can I use stock lugnuts with NISMO's ?
Just bought some used wheels on ebay 18 Inch Nismo's, seller doesn't have the Nismo lugnuts can I use the stock ones or should I get some aftermarket ones? Any recommendations?
Old May 21, 2006 | 10:26 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I don't think the stock ones will fit. The stocks have a 21mm head and the Nismos have a 17mm head. I could be wrong though.
Chris
Old May 21, 2006 | 03:14 PM
socalkend's Avatar
socalkend
thanks
Old May 21, 2006 | 05:18 PM
HyperSprite
Mad Scientist
Just so you know, you are looking for a M12x125 lug.
I just went out and measured stuff and this is what I found
It looks like the stock lug would technically fit but I did find a few issues that would keep me from using them.
The Nismo wheel uses a larger taper surface than the stock lug has. The taper does appear to be the same angle though.
You will need a thin wall 21mm socket to put them on, I was able to slide my socket in the hole but with one layer of electrical tape on it, it was snug. I know for a fact the stock lug wrench wont fit in there.
Chris
ablaine
Nov 29, 2016 10:13 AM
nanotech
Oct 2, 2015 05:02 AM
