Question about wheel offset
Old Jun 11, 2006 | 09:51 AM
meezie's Avatar
meezie
Default Question about wheel offset
I did a search, but could not find an answer.
What problems would there be if I run a 18x9 +23 all around? I remember reading something about understeer/traction problems, something along those lines, but I want to be sure before I make a purchase if there will be major cons about it. Thanks in advance.
Old Jun 11, 2006 | 10:01 AM
xav_350z's Avatar
xav_350z
i think the problem will be wiz the front wheels ,maybe theyll hit the brake calipers.
ull have to use wheel spacers
i would stick to what is recommended :
8.5 front
9.5 rear
Old Jun 11, 2006 | 10:13 AM
VenomZ's Avatar
VenomZ
that's not that aggresive of an off set...I would think you'd be fine
Old Jun 11, 2006 | 10:14 AM
VenomZ's Avatar
VenomZ
8.5 front
9.5 rear
offset and wheel width are 2 different things...
Old Jun 13, 2006 | 11:32 AM
-EL's Avatar
-EL
I'm running 18x9 +25 all around, with 265/40R18 tires all around, and have no issues whatsoever. 2mm more isn't going to cause any issues, I have plenty of clearance.
I ran this setup on our local racetrack a few weeks ago and it performed brilliantly. I also have Hotchkiss sways, and this combination cured the Z's stock understeer.
Go for it!
-E
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
