19" tire air pressure
Old Jun 12, 2006 | 08:09 PM
Speezee's Avatar
Speezee
Default 19" tire air pressure
What do you guys recommend for my new 19" tires? 35 psi? Thanks.
Old Jun 14, 2006 | 05:31 PM
Speezee's Avatar
Speezee
Default nobody has 19" tires?
n/m
Old Jun 14, 2006 | 06:03 PM
Why would the diameter of the wheel effect the recommended tire pressure?
Old Jun 14, 2006 | 06:40 PM
DavesZ#3's Avatar
DavesZ#3
40 - 42 sounds a little high. The ultimate decision has to be made on how it rides and the tires wear. 35 is probably a good starting point. You can adjust it up or down depending on how you feel the the car rides and handles.
If it feels soft and slow to respond to steering wheel input, then you probably need to start increasing the pressure. If it feels like you're riding on solid rubber, the pressure is probably too high.
If you determine that the center portion of the tire wears quicker than the outer edges, then the pressure is too high causing the tire to bulge. The opposite is true if the outer edges wear more than the center, the tire needs air.
Old Jun 14, 2006 | 07:59 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I run 35-37psi in my 19's...
Old Jun 16, 2006 | 09:11 AM
Speezee's Avatar
Speezee
Default Thanks
n/m
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
