Toyo RA-1 vs T1-R
I currently run the Toyo T1-R tires and am happy but need wider ones in the rear due to the power I put down (475whp)
I want to stay with my current wheel style and the biggest widest they come at are 18X10
If I get the T1R for this wheel the widest I can go is 285/35/18
If I get the RA-1's I can go 305/35/18 and since these are competion tires I'm leaning towards those.
Questions:
will there be a problem if I go T1R in the front and RA-1 in the rear?
How are the RA-1's anyone running them and are you happy with them?
Questions:
I've never seen someone run a RA1 in the rear and a T1R in the front and I've never driven a car with two totally different style tires front and rear so i can't comment on that.
However I have driven on plenty of T1R's and I currently daily drive on RA1's. There is no comparison between the two in terms of dry handling. The RA1's are R compound tires that plenty of people track with. On the street they are great. I am coming from S-03's for my last 2 sets of tires and the RA1's grip alot more. However I have changed my allignment a good amount. For the RA1's to grip really well you need at least -2 deg. of camber. With the RA1's i don't have traction issues anymore, with regular tires I would get loose in low gears (460whp, awd
Downsides are the cost and tread life. The T1R's will last a little over twice as long as the RA1's...
-Dan
)Downsides are the cost and tread life. The T1R's will last a little over twice as long as the RA1's...
-Dan
thanks for the info
I did some more reading on the RA-1's as well and since my camber is set more towards drag racing (I run slicks at the track) I probably wouldn't feel the advantage.
I'm going to stick to the T1-R's all around
Originally Posted by THE TECH
I've run the RA-1s before and they are a fantastic tire. There is no comparison between them and the T1R.
Also I read that they are only good if you heat them up, I want a realible tire for everyday use as well and don't want to have to do a burnout every time I drive to work
You definitely don't want to mix tires like that. Mixing street tires is bad enough, but using street tires AND race tires is definitely a no no.
We've also seen at least 5000 miles or more using the RA-1s as street tires. Gotta remember that street tires and race tires are not meant to last the same amount of time.
Originally Posted by 350Zteve
The big drawback to the RA-1 would be on the freeway in the rain. Very spooky to run such a tire at speed over water.
-Dam
bcoffee20
Nov 19, 2015 06:39 PM
raceboy
Jul 5, 2003 09:52 PM
