285/30/20 on a 10.5 wheel?
Old Jul 6, 2006 | 04:30 PM
jmaldonado's Avatar
jmaldonado
Default 285/30/20 on a 10.5 wheel?
I finally got my new wheels and tires (Axis Matrix). The tires that I got with them are 285/30/20. Is anyone else running this size tire on a 10.5" wide wheel? It looks to me to be a little streched. It looks as if the wheels in not being protected by the tire at all.
Front 20x9 255/35/20
Rear 20x10.5 285/30/20
Anyone running this setup?
Old Jul 6, 2006 | 09:59 PM
The front tires are 7.50mm taller than the rear.
Old Jul 6, 2006 | 11:10 PM
roncfpz's Avatar
roncfpz
I run 285/30/20 on 10.5 on my G and it's fine. It could be the brand of tire; some are wider than others. I'm running Michelins. Also, you might want to consider changing your front to 255/30/20.
Old Jul 6, 2006 | 11:36 PM
Z33Benny's Avatar
Z33Benny
im running the same tire size on the rear of my HRE 20x10.5 and i have a little bit of lip on the tire kinda protecting the lip. Im running the potenza s03
Old Jul 7, 2006 | 10:53 PM
superppwZ33's Avatar
superppwZ33
285/30/20 toyo t1r on 10.5 gtc
as you can see the tire lines up with the rim almost perfectly
also like others have mentioned try to run 255/30 in the front
cuz you don't want the front tires to be bigger than rear due to vdc
Old Jul 8, 2006 | 11:59 PM
ssk0771's Avatar
ssk0771
I don't drive a Z anymore but I do drive SC430 which runs similar set up as Z.
I use to have 20x10.5 Maya GR5 running 285-30-20 Dunlope SP9000.
Here is the pic
Attached Thumbnails 285/30/20 on a 10.5 wheel?-sc430-maya-gr5-20s-3a.jpg
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
