Work Wheels "Disk" Help
Old Jul 7, 2006 | 01:08 PM
plastiketa's Avatar
plastiketa
Default Work Wheels "Disk" Help
Anyone know what the difference between the "disks" are (Its on the attachement below)? I need to figure out which "disk" will fit (I have the stock brembos calipers all around).
Thanks
Old Jul 7, 2006 | 02:46 PM
A Spec Products's Avatar
A Spec Products
Thanks
L Disk is shallowest of the 3
R Disk is for standard big brake
T Disk is for mega big brake (6 pot, etc)
R Disk is fine for stock Brembos.
Old Jul 7, 2006 | 03:11 PM
plastiketa's Avatar
plastiketa
thanks A Spec!
How does the A disk compare to the R? I have on order for the rears as an A disk. Will this have a bigger lip then the R?
Old Jul 7, 2006 | 03:19 PM
A Spec Products
thanks A Spec!
You can compare lip size with the number (in mm) on the top of the corresponding column.
For the rear I normally recommend O Disk for maximum lip look.
What sizing did you order?
Old Jul 7, 2006 | 03:25 PM
plastiketa's Avatar
plastiketa
19x9.5 +24 (r disk) 19x10.5 +29 (a disk)
They said that WORK Japan said +23 on the a disk would not clear brembo so I had to go with +29.
I hope the measurements are right
Old Jul 7, 2006 | 03:31 PM
A Spec Products
You're right, O Disk won't clear in that case. It depends on the wheel, for example if its a mesh wheel like VS-XX versus a Meister.
Your fitment is fine, no sweat.
Old Jul 7, 2006 | 04:59 PM
HXS's Avatar
HXS
logan,
so for the 2-piece meister and stock brembos, can i do A disk up front and O disk rear?
thanks.
Old Jul 11, 2006 | 01:38 PM
A Spec Products
Originally Posted by hardy
logan,
thanks.
For 19" Meister, R Disk Front , O Disk Rear
For 18" Meister, A Disk Front , O Disk Rear
For Meister O disk is cool for all rear with brembo.
Old Jul 11, 2006 | 05:26 PM
Zexy's Avatar
Zexy
Would R disk clear 355mm big brake kits?
Old Jul 11, 2006 | 05:32 PM
A Spec Products
Yes, as long as the offset was correct.
Old Jul 12, 2006 | 07:04 AM
03Z33's Avatar
03Z33
Aspec, how does offset affect brake clearance?? It does NOT. As long as you choose the correct disk it will clear your brakes no matter what the offset.
The sizes you ordered will fit the car fine, but you can easily fit more wheel/lip under the Z. If it's not too late, you should change the order to:
Front: 19x9.5 +19 (L Disk) or 19x9.5 +12 (R Disk)
Rear: 19x10.5 +23 (O Disk) or 19x10.5 +16 (A Disk)
The above setup will maximize your lip without going too aggressive on the fittment.
as Aspec mentioned (O Disk) clears stock Brembo rear brakes and will give you the max lip. L Disk will also clear the front stock Brembo, and give you a little more lip (at the expense of a less concave look to the wheel).
what's more important to you, lip size or spoke design? if spoke design then go with R Disk front and A disk rear which will have more curvature.
Old Jul 12, 2006 | 07:16 AM
03Z33's Avatar
03Z33
If you want the most aggressive fittment for a lowered car with rolled rear fender you can fit:
Front: 19x10 +18 (L Disk)
Rear: 19x11.5 +23 (O Disk)
Old Jul 12, 2006 | 12:54 PM
A Spec Products
Easy there.
I meant that yes, R disk will work, and if he chooses the right offset, it will fit (his car). I wasn't saying that offset determined the brake clearance.
The Meister S1 has good x factor to begin with, which is why the R disk can work in this situation.
And 03Z33, I know you can run 10/11, but most guys don't want to be that aggressive.
The sizing he's going with is fine, don't make him worry.
Old Jul 12, 2006 | 09:59 PM
03Z33's Avatar
03Z33
Hey man it's all good, I was just having fun with you
Who is this anyway? Francis? Logan? other???
JjL
East Canada
Jun 12, 2019 03:04 AM
davidm350
Oct 31, 2015 02:28 PM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
Shane86
Sep 17, 2015 05:33 PM
Beater350z
Sep 9, 2015 03:36 PM
