12mm Wheel Spacers (where to get?)
Old Feb 22, 2003 | 03:15 PM
wadd3456's Avatar
wadd3456
Default 12mm Wheel Spacers (where to get?)
Where can I purchase a set of 10 or 12mm spacers? I was going to make my own set out of some 7thousand series aluminum but someone mentioned they were cheap to buy.
Any idea where I can pick up a cheapy set? I may only need 2, now that I think about it. Ive seen them for 100+ but is that 1 or a whole set? I would HOPE a whole set. But like I said, I may only need 2.
Thanks
Old Feb 22, 2003 | 03:33 PM
teh215's Avatar
teh215
Someone will probably have a better solution than this but, a local machine shop could probably make them for you to the exact specs. Otherwise try www.summitracing.com or www.jegs.com , they usually carry generic ones.
Rob
Old Feb 22, 2003 | 03:42 PM
wadd3456's Avatar
wadd3456
Yup, I was going to cut my own, but if its cheaper to buy it then to make it, i will just buy it
Old Feb 22, 2003 | 04:10 PM
djkern's Avatar
djkern
http://store.summitracing.com/partdetail.asp?part=9325
which one of these would fit the z?
i am going to make them myself....but i need the specs!
also....am i going to need to get new bolts for the lug nuts (longer ones...or will the ones on there fit still??)
thanks,
djk
Old Feb 22, 2003 | 04:29 PM
rodH's Avatar
rodH
do a search for H&R wheels spacers, I found lots of info that way
Old Feb 22, 2003 | 06:58 PM
wadd3456's Avatar
wadd3456
You will need 60mm lug bolts which can be purchased just about anywhere.
Just tap them out with a hammer and push the new ones through.
Obadabot
Jun 18, 2023 11:31 PM
