Tire suggestions
Old Jul 17, 2006 | 10:46 PM
TotalChaos's Avatar
TotalChaos
Default Tire suggestions
Sizes that is..
Wheels are 18 x 8.5 / 18 x 9.5 35mm offsets
Appreciate any help you guys can give me!
Old Jul 17, 2006 | 10:54 PM
ssk0771's Avatar
ssk0771
First of all, the offset you listed above is little conservative for 350Z. Your wheels/tires will be little too tucked. You might want to add some spacers if you want it to look right.
As for tires,
Front: 245-40-18 Rear: 275-40-18
Hope this helps.
Old Jul 18, 2006 | 07:30 AM
TotalChaos's Avatar
TotalChaos
Really? a +35mm offset will be too little? What size spacers would you suggest?
Old Jul 18, 2006 | 08:14 AM
Pac Man's Avatar
Pac Man
15mm for fronts and rears.
Do you have the wheels already?
Old Jul 18, 2006 | 11:30 AM
TotalChaos's Avatar
TotalChaos
No
Old Jul 18, 2006 | 11:42 AM
Pac Man's Avatar
Pac Man
No
Ok, then personally I would shoot for a little more aggessive offset like +20 and do without the spacers. Just my $.02.
Old Jul 18, 2006 | 12:32 PM
TotalChaos's Avatar
TotalChaos
so.. (forgive me.. i'm new)... the lower the number in the offset, the more the wheel will 'stick out' on the car?
Old Jul 18, 2006 | 12:49 PM
ssk0771's Avatar
ssk0771
Yes.
I use to have Volk SF Challeng on my Z Roadster and these were the offsets.
F: 19x8.5 with +21 offset.
R: 19x9.5 with +23 offset.
Also, Z can take little more aggressive so 15mm spacer with your current setup should work.
As for spacers, try to get a name brand. I had Kic's spacer and they were pretty good.
The good thing about Kic's sparcer is that you don't have to get long studs. Its like an adaptor so spacer get bolt on to the rotors where stock studs are and spacer has its own studs comming out which you can use to mount the wheels.
Old Jul 18, 2006 | 12:55 PM
Pac Man's Avatar
Pac Man
You got it!
I would suggest checking this out as well.
https://my350z.com/forum/showthread.php?t=141766
Old Jul 18, 2006 | 04:26 PM
TotalChaos's Avatar
TotalChaos
Thanks for the info ssk.. I will look into them a little bit more.
But from reading into this a little bit, this is what I do not understand.
hese are stock specs:
Base Enthusiast
front - 17x7.5, +30mm
rear - 17x8.0, +33mm
Now, if I am putting on a rim that has just 2 more mm offset in the rear (+35mm), AND the rim itself is a full inch wider.... why would that not stick out more??? I must just be missing something really stupid here... but I really appreciate all the help you guys are giving me!
Old Jul 18, 2006 | 04:54 PM
ssk0771's Avatar
ssk0771
Base Enthusiast
Thats because stock wheels have convservative offset so they tuck in alot. That how most stock/OEM wheels are made.
Thats why some guys that are buying 19" Rays OEM wheels for G35/G35C use spacers.
Car just does not look right if wheels are too tuck in. Especially with after market wheels.
Another example is I drive an SC430 where the factory OEM wheels are 18x8 with +45 offset(estimate???) all the way around and I am currently running 20x10 with +23 or +24 offset in the rear which is way more aggressive that stock/OEM wheels.
Car companies like to play safe so they use conservative offset on OEM wheels.
ablaine
Nov 29, 2016 10:13 AM
