need wheel lock recommendations
Old Jul 23, 2006 | 05:02 PM
o snap its eric's Avatar
o snap its eric
Default need wheel lock recommendations
what are some that you guys suggest?
Old Jul 23, 2006 | 05:09 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
what kind of wheels so we know what fits...
Old Jul 23, 2006 | 05:16 PM
DavesZ#3's Avatar
DavesZ#3
Also, what look are you going for? Do you want just locks or a matching set of nuts and locks?
You can get the stock type locks which come from McGard. Gorilla has some hex socket ones that I've been thinking about getting myself. There are high end ones like the Volk Duralum that come with a "lock" nut.
Old Jul 23, 2006 | 05:52 PM
o snap its eric
i just want ones that work so theieves can get to them as fast and does not stick out or draw away from my rims. I have the nismo lmgt4.
im also using the stock lug nuts too
Old Jul 23, 2006 | 06:14 PM
DavesZ#3's Avatar
DavesZ#3
You do realize that none of them *really* work? Anybody but a amatuer thief will be able to get them off pretty easily. You're really only hoping to slow them down
As I mentioned before, I've been looking at the tuner style nuts/locks from Gorilla. They're small so they work with my Volk wheels. Because they are "inside" drive, you don't have the risk of scratching the wheels around the lugs like you do with a normal socket style.
http://www.gorilla-auto.com/products...image=5545.jpg
Old Jul 23, 2006 | 06:15 PM
Volk350Z's Avatar
Volk350Z
Master
YOu can use the Rays or Kics lugs sets. if you just want lock you can run Bull Lock....
Old Jul 23, 2006 | 06:17 PM
DavesZ#3's Avatar
DavesZ#3
Brian - why doesn't Rays make the Duralum lightweights in a silver finish?
Old Jul 23, 2006 | 07:23 PM
o snap its eric
so many choices!
so what sizes do i need? I have nismo lmgt 18"
where can i find the volk wheel locks and lug nuts?
bull locks, how good are they. Like what davesZ said, none of them will deny theives but only slow them down.
sorry im very lost. I thought this would be a simple process of just buying some locks but i didnt know there are so much to consider, like shape and size, etc. Would be great it someone can help me out. Im just looking for wheel locks for under 50-100 bucks and lug nuts for 130 and under. Is there such thing as everything in one? Thanks!
Old Jul 23, 2006 | 08:50 PM
Jason@Performance
Performance Nissan
for LMGT4's the best ones ive found are the mcgard wheel locks... that is if you want to spend the least amount...they come in black to match your other lugs...
if you want to spend more... any of these work...
http://www.mynismo.com/categories/?id=2325
Old Jul 23, 2006 | 08:56 PM
NA350Z's Avatar
NA350Z
YEP! ! ! They're mighty pretty too.
Old Jul 24, 2006 | 10:32 AM
o snap its eric
how are the bull locks? Can they be broken easily? im planning on getting 2 sets of wheel locks. Anyone know where i can get them at for our cars?
Old Jul 24, 2006 | 02:05 PM
DavesZ#3's Avatar
DavesZ#3
Breaking the lock is not the problem. I broke the key on my OEM (McGard) locks. To remove it, we hammered a 3/4" socket over the locking lug nut then used an air wrench to unscrew it.
Old Jul 24, 2006 | 02:44 PM
o snap its eric
so basically any wheel lock are the same? I know the OEM ones can be broken easily, just wondering how the aftermarket one stacks up.
Old Jul 25, 2006 | 08:08 PM
VJD's Avatar
VJD
Jason,
Price aside what is the best quality wheel lock on the market that will match the black lug nuts on my LMGT4's? Thanks
Old Jul 25, 2006 | 11:09 PM
DHCrocks's Avatar
DHCrocks
personally I would stay away from Aluminum lugs/locks. They are much too soft and sooner or later will endup getting cross threaded or stripped. Wheels need to be torqued down to around 85 ft-lbs and steel is a much better option. Using an aluminum nut on a steel bolt is also not ideal as it could lead to galvanic corrosion due to the dissimilar metals. I use Mcgard lugs and locks, they are not too expensive and do the job.
Obadabot
Jun 18, 2023 11:31 PM
