What Toyo T1Rs are "NOT" supposed to look like
Old Aug 13, 2006 | 10:56 PM
  #41
sokudo9l6's Avatar
sokudo9l6
can you find your alignment sheets and post them up? I want to see the specs.
Old Aug 15, 2006 | 05:49 PM
  #42
NISMOFO's Avatar
NISMOFO
Yeah, I have these tires as well...I have rear camber/toe kit and realignment but I think I'm still running too much toe. Mine are scrubbing a little
Old Sep 16, 2006 | 06:41 PM
  #43
redman333's Avatar
redman333
Ok I have a stock suspension but my tires look the same, why would mine look that way. I only had 5k on them.
Old Sep 17, 2006 | 04:49 AM
  #44
drumma022's Avatar
drumma022
"Close to NIssan spec" is their way of saying your alignment is still not right.
Nissan Service Manual says that 0.2mm to 1.8mm of total toe in and from -1 to -2 degrees of camber is acceptable for the rear.
The front is 0mm to 2mm of total toe in and from 0 to -1.33 deg camber.
If they put the car to 1.8mm and 2mm of toe respectively, you are within spec but still way off!
Old Sep 17, 2006 | 06:27 AM
  #45
bam025's Avatar
bam025
My tires looked the same way after being lowered on eibachs for about 8months. Caused me to slide off the road one wet morning. My toe/camber were facked up bad. More camber than toe however. Then actually started to look at it and my back tires looked like this / \. So when I got my new Z, I went with an Tein s-tech drop. granted not as much drop as the eibachs, but my tires still look new after a year or so. That suxs...
Old Sep 17, 2006 | 09:43 PM
  #46
=BANKS='s Avatar
=BANKS=
Penis ME!
FAAWWKK!! I just got done changing my front brake pads and I too have toyo t1r's.....and the inside is wearing out I can the see a little of the white thread!! I have 19's dropped with tein s techs shiet....so from what im reading is that its a camber/toe problem???
hulkout
Apr 28, 2017 09:00 PM
bcoffee20
Nov 19, 2015 06:39 PM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
