Knock from rear right wheel
Old Aug 6, 2006 | 06:54 AM
Spec_Tacular's Avatar
Spec_Tacular
Default Knock from rear right wheel
I am getting a bit of a clicking, knocking kinda noise from my right rear wheel when I start to move from a stop. Anyone have any idea what this might be?
I am having my Nismo spring and shocks installed in 2 days so I am going to have the tech look at the same time.
Old Aug 6, 2006 | 07:16 AM
brooke's Avatar
brooke
It should just need some Grease and retightning...
brooke
Old Aug 6, 2006 | 07:32 AM
reptile718's Avatar
reptile718
brooke I have this same problem. It use to be a creaking noise then I sent it to a mechanic that said some things where loose in my rear end and tightened them now I get a clicking or knocking. What grease to use and where also what needs to be tightened?
Old Aug 6, 2006 | 05:38 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
sounds like the axle TSB to me
Old Aug 7, 2006 | 04:42 AM
reptile718's Avatar
reptile718
how can I fix it?
Old Aug 7, 2006 | 05:17 AM
Z1 Performance
Former Sponsor
look up the TSB chart online and see if your car;s VIN number applies - if it does, bring it to the dealer and they will replace the necessary parts
Old Aug 7, 2006 | 05:22 AM
reptile718's Avatar
reptile718
don't wanna sound like a newb but what is the link to the TSB charts and does it matter if I have lowering springs and after market sways on my car?
Old Aug 7, 2006 | 07:24 AM
SpeedRcr's Avatar
SpeedRcr
no it wont...the tsb doesnt replace any of those parts
Old Aug 7, 2006 | 07:55 AM
reptile718's Avatar
reptile718
I saw the bulletin out for the clicking rear axles and when I called my Nissan dealer they told me it would not be covered b/c my warranty period is expired. Is that true even though its a defect in the vehicle?
Old Aug 8, 2006 | 08:10 AM
Spec_Tacular
where did you find the bulletin?
Old Aug 8, 2006 | 09:15 AM
Spec_Tacular
Ok I found the bulletin at work today. (I sell at a Nissan Dealership) Anyway it says to grease the axle links and had a diagram. Our master tech is installing my Nismo suspension and Volk GT-Cs tonight and he said he'd do that aswell.
Also my car squeaks from the left rear wheel when I go around left turns. Do you guys think it is possible that its because my brakes are shot? My new discs are on back order so I am hoping they can do something in the intern to stop the squeal.
Obadabot
Jun 18, 2023 11:31 PM
