Studs not long enough for wheels?
Originally Posted by baileyrx
Q. I can't get my new rims to fit on the front. There's a little bolt there! What can I do??
A. That little bolt is there so your tire guys don't put your stock rear rims on the front by mistake. To install aftermarket rims, just get a 10mm wrench & unbolt it. Problem fixed!
That doesn't sound right.. we helped a friend install her 19" GT-C's in April and her studs were fine (albiet a little short but fine)
are you sure the wheel is seated properly on the hubcentric ring? it does take some force to get it in.. and you have removed that safety bolt in front?
---mike
---mike
Thats the other thing. The distributer told me I wouldn't need a hubcentric ring. They are one of 3 distributers that Mackin Industries list so I figured they knew what they were taking about.
--mike
Ok I just spoke to the guy that I got the wheels from and he sad he screwed up and that the GT-C requires a special lug and he is sending them right away.
**APPARENTLY THEY NEED WHAT IS CALLED A SHANK LUG?
