Nitto 555 Tire Pressures
Old Aug 14, 2006 | 09:55 AM
06Firebase's Avatar
06Firebase
Exclamation Nitto 555 Tire Pressures
These are the tires that came with my car: 225/45ZR18 (95W) on the front, and 265/35ZR18 (93W) on the rear.
The stock rear size is supposed to be 245/45ZR18 (100W), right? So I guess the previous owner had these put on. Great tires.
Anyway, I asked the Nissan dealer about them, but he didn't know.
I set all four tires at 35psi anyway as has been discussed elsewhere on these Forums.
Just found out from Nitto that due to the (93W) rear rating, I need to increase my rear tire pressures to 40psi. They said that 35psi was OK on the fronts.
Just thought I would pass this info along to you.
Joe
Old Aug 15, 2006 | 03:09 PM
TTRANK's Avatar
TTRANK
Thanks!
I have been keeping mine at 30F ~32R.
I will put some more air in them tonight.
Old Aug 16, 2006 | 02:01 PM
BluZee's Avatar
BluZee
I put 35psi all around. Have had them for 29,000 miles and theres no abnormal wear.
Old Aug 17, 2006 | 04:05 AM
06Firebase's Avatar
06Firebase
Question
OK . . . what are the tire sizes and weight ratings of your Nitto tires?
Old Aug 17, 2006 | 04:33 AM
93 is a load index based on the potential weight over the axle. You can use a tire with a load index equal to or greater than that recommended by Nissan. The load index does not change the pressure required to support the potential weight over the axle. I recommend 35psi all around.
Old Aug 17, 2006 | 04:37 AM
BluZee's Avatar
BluZee
I have 245/40-18 front and 275/40-18 rear. I have no idea what the weight ratings are.
Old Aug 19, 2006 | 06:01 AM
06Firebase's Avatar
06Firebase
Smile
Right, David
The fronts are supposed to be 91W and the rears are supposed to be 96W.
The Nitto factory rep said that my rear tires were "not recommended" for my car, and suggested that "in the meanwhile" I increase their pressure from 35 to 40psi. This implies that adding extra air is not a panacea for getting the wrong tires in the first place.
But when I got the car, I didn't know any better. I am now sorting out all the little bugs and mistakes that the previous owner made.
Can you explain why a lower weight rating (91W) is used in the front where all the engine weight is?
Thanks, Joe
Old Aug 19, 2006 | 09:16 AM
Carrying items in the back? Towing something? I am not sure.
Old Aug 21, 2006 | 09:45 AM
Elohite's Avatar
Elohite
My Nitto 555's are
235 / 40 / 18 Front
275 / 35 / 18 Rear
I got 32 psi alla round...
Should i fill up with more air?
Old Aug 22, 2006 | 04:16 AM
06Firebase's Avatar
06Firebase
Talking
Originally Posted by Elohite
My Nitto 555's are
235 / 40 / 18 Front
275 / 35 / 18 Rear
Well, if you've been following this thread, you should have at least 35psi all around. That much we seem to agree on. This is the recommended pressure as found inside the console box no matter what brand of tire you are using (Nitto, Bridgestone, Goodyear, etc.)
What I am saying is that the Nitto factory rep told me to put another 5 psi in my rear tires. this is because the weight rating of my rear tires is not high enough. Mine are only 93W, not 96W or higher. Davidv says adding extra pressure is incorrect. I am still looking into this.
The stock tires from Nissan are 91W in front and 96W in the rear. Check to see what weight ratings are on your tires. In the meanwhile, I would put 35psi in all around.
All best,
Joe
Old Aug 22, 2006 | 04:35 AM
rich harris's Avatar
rich harris
well said....
245x35x20
275x30x20
35psi all a round....
Old Aug 22, 2006 | 04:51 AM
booger's Avatar
booger
245 x 35 x 18
275 x 35 x 18
35psi all around
Old Aug 29, 2006 | 08:54 AM
06Firebase's Avatar
06Firebase
Cool
The necessity of increasing my rear tire pressure due to the lower weight rating of my rear tires was just verified by a rep from Tirerack.com
So both Nitto and Tirerack agree on this.
When it's time to replace these tires, I'm going to use 245/45-18 (96W) UHP all-season tires front and rear. In the meanwhile, I will put 35psi in my Nitto 225/45-18 (91W) front tires and 40psi in my Nitto 265/45-18 (93W) rear tires as recommended by the experts.
All best,
Joe
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
