Work CR Kai 18X9.5 +20 on SB
Old Aug 16, 2006 | 06:05 AM
THE TECH's Avatar
THE TECH
Originally Posted by masterj26
what size tires the tech?
245 front, 275 rear
Old Aug 16, 2006 | 10:11 AM
A Spec Products's Avatar
A Spec Products
Originally Posted by smellslikecurry
logans the man
full car pics soon i promise
no, you're the man, rockin dat +12 like a damn G
Originally Posted by jimster716
Logan is a dorifto Silvia poseur. Tires to him can't be stretched enough for that oh so good JDM look. Grip pwns joo Logan. I remember when he was just a wide eyed student coming in to my office to bug about JDM 240 heaven.
J/K foo. Actually I'm not but you know that.
ah crap, my cover is blown
215's on da 9's, thats how it goes down!
Originally Posted by THE TECH
245 front, 275 rear
i assume 245/40, 275/35?
Old Aug 16, 2006 | 11:37 AM
THE TECH's Avatar
THE TECH
275/40
Old Aug 16, 2006 | 10:23 PM
smellslikecurry's Avatar
smellslikecurry
i need to fix the camber in the rear and slap on some 275s then stance will be perfect...also little lower all around...it actually looks higher than it is here cuz my driveways at an angle...ill take pics on a flat surface....freaking slammmmed
Old Aug 17, 2006 | 05:59 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Stance is perfect IMO, just some meatier tires in the back. I'm loving this setup right now...Do you have much room for the 275's in the rear?
Old Aug 17, 2006 | 06:07 AM
THE TECH's Avatar
THE TECH
There is plenty of room for 275s. No rubbing whatsoever.
Old Aug 17, 2006 | 06:19 AM
Vq.turbo.DremZ
But with +12 offset in the rear? The +12 9.5 has more concavity than the +20 9.5 correct?
Old Aug 17, 2006 | 06:26 AM
leykias's Avatar
leykias
^^^^^^^ correct!!!
Old Aug 17, 2006 | 06:33 AM
jjellyneck's Avatar
jjellyneck
I've usually been a fan of a clean 5 spoke wheel or a nice mesh (but a pain to clean). These wheels fit the Z great. It's a clean look, somewhat different, and they aren't heavy. Aggressive and elegant at the same time.
Old Aug 17, 2006 | 06:44 AM
Vq.turbo.DremZ
Originally Posted by leykias
^^^^^^^ correct!!!
Well if thats the case, than maybe 18x9.5 +20F and 18x9.5+12R would look better and fitment would be easier.
Old Aug 17, 2006 | 07:04 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
The Emotion with a 18x9.5 +12 WILL rub in the rear, badly in fact, with a 275/40 - once the fenders are rolled, no problem at all. Even the 18x9.5 +20 will rub with some brand tires of the 275/40/18 size (as evidenced by my own car). No amount of rear camber fixed my rubbing (had it up to 4 degrees, which also puts toe way out of spec, still rubbed occassionally with me in the car, and rubbed over ever bump with a passenger). Once I rolled the fenders, it never rubbed again, and I was able to dial back to my preferred 2 degrees rear camber and perfect toe. Rideheight, camber and the exact tire you run (not the size, but the specific tire) will determine rubbing vs not rubbing.
the 9.5 +12 and 9.5 +20 have the same spokes, same pad height and as a result, same amount of concavity
Old Aug 17, 2006 | 07:43 AM
leykias's Avatar
leykias
guessss i'm wrong
i just thought the offset was the factor that determining the degree of concavity....
Old Aug 17, 2006 | 07:45 AM
Z1 Performance
Former Sponsor
The pad height and offset together determine concavity, just as they determine lip width - the two go hand in hand
Old Aug 17, 2006 | 08:12 AM
Vq.turbo.DremZ
Well if thats the case, do you even reccommend 18x9.5 +12 all around? Also this has nothing to do with CR Kai's but Do you happen to know all the size and offset options for XD9's? I can't seem to find them on their website.
Old Aug 17, 2006 | 08:19 AM
Z1 Performance
Former Sponsor
recommend? depends what you want
If you want a wheel that sits as far out to the arches as possible, then yes, they are great. You will need fender mods, and you may be limited on tire choice - only you can decide if the plusses outweight the minusses.
As for the XD9, here you go
17x7.5 +50, +42, +32
17x8.5 +42, +32, +25
17x9.5 +44, +38, +28, +17
18x8 - +45, +35, +28
18x9 - +43, +38, +30, +20
18x10 - +38 +18
Old Aug 17, 2006 | 08:23 AM
THE TECH's Avatar
THE TECH
Old Aug 17, 2006 | 08:27 AM
Vq.turbo.DremZ
18x10 - +38 +18
I Like the look of smellslikecurry's car but with just a fatter tire in the back. You said fender mods, I assume just rolling the rears? This may be impossible but 18x10 +18 in the front are probably not going to fit without extensive fender mods, right?
Old Aug 17, 2006 | 08:28 AM
  #38
Vq.turbo.DremZ
I'm seeing an X...
Old Aug 17, 2006 | 08:43 AM
  #39
smellslikecurry
18x10 will need tons of negative camber...talk to josh at autornd about fitting crazy wheels...hes the king of fitting 18x10 -5 offset wheels...crazy **** like that
Old Aug 17, 2006 | 10:28 AM
  #40
Z33_SPL's Avatar
Z33_SPL
18x10 +18 will have the same fender clearence as a 18x9.5 +12 up front.
smellslikecurry, looking good. quick question, you think you have enough room for some 255/35/18s up front? I was planning on running this tire size on my 18x10 +18 xd9s all around.
