Work CR Kai 18X9.5 +20 on SB
Old Aug 17, 2006 | 10:38 AM
  #41
A Spec Products's Avatar
A Spec Products
Originally Posted by THE TECH
275/40
We prefer going with the 275/35 rear to match up to stock tire profile
F: 18x9.5+12 w/ 235
R: 18x9.5-3 (15mm spacer) w/ 255
Technically this car was used for drifting, which explains the stretch tire
No rolling no rubbing according to customer
Old Aug 17, 2006 | 12:03 PM
  #42
THE TECH's Avatar
THE TECH
F: 18x9.5+12 w/ 235
R: 18x9.5-13 (15mm spacer) w/ 255
Looks nice nonetheless.
Old Aug 17, 2006 | 07:33 PM
  #43
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
18x9.5 -13? they make that offset? Also concavity is the same as +12 correct?
Old Aug 17, 2006 | 07:34 PM
  #44
Vq.turbo.DremZ
Originally Posted by Z33_SPL
18x10 +18 will have the same fender clearence as a 18x9.5 +12 up front.
smellslikecurry, looking good. quick question, you think you have enough room for some 255/35/18s up front? I was planning on running this tire size on my 18x10 +18 xd9s all around.
Really? When do you plan on doing this setup?
Old Aug 18, 2006 | 07:44 AM
  #45
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
VQ - they dont make negative offsets
Old Aug 18, 2006 | 07:48 AM
  #46
Z1 Performance
Former Sponsor
VQ - you can run as fat of a tire as you are willing to make work. Some will require simple rolling, some will require cutting the lips totally, others will require cutting the lips and pulling the fenders. How much work are you willing to do for a $1400 set of wheels?
the problem with all the big sizes up front with the very low offsets is that turn in response turns from razor sharp to "am I driving a caddy", not to mention the absolute punishment the already crappy balljoints take as a result
Old Aug 18, 2006 | 09:04 AM
  #47
Vq.turbo.DremZ
Thanks for the info, i was just wondering about the 10" XD9 in the front and how they would look. I'm settling on the 18x9.5 +12 pending on the look and fitment of smellslikecurry's 275/40 rears. If anything i can fall back on the +20 all around or 8.5+20F 9.5+20R. Tires are a def 245/40F 275/40R, just need to decide on offset.
Old Aug 18, 2006 | 09:09 AM
  #48
Z1 Performance
Former Sponsor
but you're talking about 2 totally different wheels....XD( and CR Kai don't come in the same sizes/offsets
Old Aug 18, 2006 | 09:19 AM
  #49
Vq.turbo.DremZ
Yeah i know someone brought up the XD9's in another thread and Z33spl is going to run XD9 18x10 +18 all around, I was jus intrigued at the setup. The specs that i want to run are all for CR Kai's Sorry about the mix-up.
Old Aug 18, 2006 | 02:54 PM
  #50
A Spec Products
I made a mistake
Its a 18x9.5-3
15mm spacer on a +12 = -3
Old Aug 19, 2006 | 07:42 PM
  #51
Spoiled Z's Avatar
Spoiled Z
I'm planning on getting this wheels in a few weeks 18x9.5 all around I want to minimize road noise as possible that is why I want to get 245/40 and 275/40 Will I rub at all? Do I need my fenders roll? Thanks in advance.
Old Aug 20, 2006 | 07:28 PM
  #52
Z1 Performance
Former Sponsor
depends how low your car is, and what specific tire you pick - the rear may need rolling, front will be fine
Old Aug 21, 2006 | 07:27 AM
  #53
Pac Man's Avatar
Pac Man
First350, your car looks evil; I like it! Almost went with the same setup myself but felft the CS on the GM would look a little too funky for my taste. Again, nice job!
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
